#1 Posted : Friday, 20 May 2005 11:20:50 PM(UTC)
Hey all,
About to go through the pain of yet another minor makeover - already know its going to blow out - and want to change the fuel tank out of the xw (sedan). I want to explore the idea of using an alloy drop tank so as to free up more boot space.
Anyone had experience with living with a drop tank, or know who i can talk to to organise one to be made, or heaven knows someone who manufactures alloy tanks for the xw/xy series!
#2 Posted : Friday, 20 May 2005 11:44:56 PM(UTC)
Try a Boat Builder or get hold of Andrew at Streetneat Panels on Brisbane's Southside. Tell him that Qute sent you.
[Edit] While Andrew may not be able to supply you with a tank, he should be able to direct you to someone who can make one as he sells l
Edited by user Saturday, 21 May 2005 4:22:28 AM(UTC)  | Reason: Not specified
GMH1975 Offline
#3 Posted : Saturday, 21 May 2005 3:19:12 AM(UTC)
GMH1975
Anyone know what grade and how thick the alluminium is thats used in drop tanks?
Not the BLOODY Kingswood
gmholdman Offline
#4 Posted : Saturday, 21 May 2005 5:42:59 AM(UTC)
gmholdman
Just had one made for a FJ ute, holds 95 litres, 3mm material.
#5 Posted : Monday, 30 May 2005 3:12:19 AM(UTC)
Any hints in making the tank ?
l need to make 1 for a tonner running injected 304.
l want to basically make it the same as the orignal out of stainless and mount the lift pump, surge tank and main pump forward of the tank. Any clues on breathers, supply
GMH1975 Offline
#6 Posted : Thursday, 16 June 2005 6:22:41 PM(UTC)
GMH1975
Hi gee tee im currently doing the same but for a sedan.
I bought the ank out of a vn and cut it open to see ho it is all setup and i will use the internal swirlpot in my new tank.
SEnd me your email and i can send you some pics that i ook of the tank o
This page was generated in 0.220 seconds.
