61 Pages«<56789>»
hx-sandman Offline
#121 Posted : Monday, 26 June 2006 7:26:25 PM(UTC)
hx-sandman
The white sandman ute link is http://www.cardomain.com/ride/804218
I e-mailed the guy about 18 months ago - the 5 white utes thing was something he was told by a friend of a friend of a friend ;-)
hx-sandman Offline
#122 Posted : Monday, 3 July 2006 7:46:40 PM(UTC)
hx-sandman
#123 Posted : Wednesday, 12 July 2006 4:56:01 AM(UTC)
Originally posted by hx-sandman
Hi Byron,
Care to give us a breakdown of how many you have recorded?
eg HQ ute 17 HQ Van 34 etc
The numbers recorded so far:
HQ: 22 total. 21 vans (2 x 202, 12 x 253, 7 x 308). 1 ute (308 Kingswood).
HJ: 19 total. 17 vans (3 x 202, 7 x 253, 7 x 308). 2 utes, 1 x 253 HOLDEN, 1 x 308 Kingswood.
HX: 20 total. 19 vans (1 x 202, 5 x 253, 13 x 308). 1 ute (202).
HZ: 24 total. 17 vans (6 x 253, 11 x 308). 7 utes (3 x 253, 4 x 308).
hx-sandman Offline
#124 Posted : Wednesday, 12 July 2006 7:25:33 PM(UTC)
hx-sandman
I have another HX ute - thought I sent it to you about a year ago.
HX Coupe Utility
2/77
GVW: 1860kg
Seating Capacity: 2
AHX 23563S
Model: 8WM80XR
Body: 916343-S
Trim: 1890-18V
Paint: 568-15953
Engine: L31
Trans: M21
RRAxle: GV4
Tyre Placard: 9942991
Description: C78514 - 558kg load
#125 Posted : Sunday, 24 September 2006 2:05:44 AM(UTC)
hello there,abit of info! i just removed compliance plates from my hz panelvan and on the back of the plate it has in red ink the number 88 written, has anyone ever seen numbers hidden under the compliance plates etc before ? thanks byron.
jam
#126 Posted : Sunday, 24 September 2006 3:17:34 AM(UTC)
What are the last two numerals of the VIN number (skinny plate)? Ignore the Z.
#127 Posted : Monday, 25 September 2006 4:37:20 AM(UTC)
gday byron , the number is 88 lol on the skinny plate. .cheers jam
#128 Posted : Monday, 25 September 2006 7:22:25 PM(UTC)
That is what the 88 on the ADR plate means ie it belongs to that VIN plate. On all HZs the body number on the BODY plate matches the PSN (last letter and numbers minus the suffix off the VIN number eg H989788 where the VIN was 8M70THH989788Z)) on the VIN plate so they must have written the last two digits of the PSN on the back of the ADR plate so there was no mixup.
#129 Posted : Monday, 25 September 2006 7:50:43 PM(UTC)
verygood thanks byron.this van i have has rust everywhere.i have cut the roof off and was going to try and put another 1 on! do u know any 1 that has done this or do u think it might be easier to look for another shell,rusty all over.any feedback would be most appreciated thanks again
jam
#130 Posted : Monday, 25 September 2006 11:03:17 PM(UTC)
Keep in contact with Greg at ClassicOzWreck on 02 49598999. He gets good stuff in all the time.
#131 Posted : Wednesday, 27 September 2006 4:42:14 PM(UTC)
thanks byron.another question for you! the shell on hq and wb are they the same as hj hx and z. panel van that is .thanks again
jam
#132 Posted : Wednesday, 27 September 2006 6:19:55 PM(UTC)
All different, except HX/Z are close.
HQ has two types - 1971-?/1974 had side flutes just above and behind the doors. ?/74 to the end of HQ had no side flutes. HQ had HQ plenum. HQ also had no provision for retractable seat belts.
HJ had HQ wiring harness and hence big plug in firewall. Clutch linkage/rat-trap support on firewall is different to HX/Z. Other firewall harness holes differ slightly.
HX/HZ are very close, with only some minor differences. Somewhere in here the acclerator pedal became welded on instead of bolted. Plus later HZs had the two clutch pedal pivot points up under the dash. Second point is for 6cyl full cable clutch setup.
WB have windscreen washer points in the plenum plus no quarter panel lights. Some body bolts became metric thread at some stage in WB - never figured out when and which exactly.
#133 Posted : Thursday, 28 September 2006 6:27:58 PM(UTC)
thanks again byron,im looking for a hz shell if anyone can help
cheers jam
#134 Posted : Tuesday, 10 October 2006 7:52:00 PM(UTC)
can any one tell me what colour sandman decals go with persian sand paint. thank you.
#135 Posted : Tuesday, 10 October 2006 11:38:15 PM(UTC)
hi there,
i think i have a HX sandman ute?
built 9-76, AHX 11133S
GVM - 2200KG
Seating Capacity - 2
model - 8WM80XR
BODY - 904055 S
TRIM - 1890 - 18V
PAINT - 568 - 15953
Tyre Placard - 9942827
eng - L31
trans - M21
raxle - GV4
Any help would be greatly appreciated
cheers Tom
#136 Posted : Wednesday, 11 October 2006 3:23:03 AM(UTC)
Yep. Its an XU3 HX Sandman ute. Slate trim (18V) was only available on a HOLDEN (nee Belmont) if it was a Sandman on Australian destined vehicles. Other base models with black trim got black trim (19V). In NZ however, 18V was standard on all base models.
#137 Posted : Sunday, 15 October 2006 7:36:56 AM(UTC)
Does anyone know how i can get a hold of a build sheet on a Hx Sandman ute as i have just got one and i wanna put it back to original ?
#138 Posted : Sunday, 15 October 2006 7:50:54 AM(UTC)
also can you tell me if this is a sandman ute
model.. HX8WM80
body no.. 214971-A
trim.. 2214-18V
paint.. 568-15991
eng.. L32
trans.. M20
rr axle.. GV7
gvw.. 1860kg
seating.. 2
8M80RGL364663X
#139 Posted : Sunday, 15 October 2006 5:56:31 PM(UTC)
Yes. Its an XX7 HX.
#140 Posted : Monday, 16 October 2006 4:39:20 AM(UTC)
but it doesnt have XX7 on the compliance plate...... and also would you know how i can findout the build sheet specs?
Guest (17)
61 Pages«<56789>»
This page was generated in 0.177 seconds.
