61 Pages«<1920212223>»
#401 Posted : Tuesday, 27 May 2008 2:13:03 AM(UTC)
It would have to be AHX08313B. I cant see it properly in either the photo of the ADR plate or the chassis number.
adam PERTH Offline
#402 Posted : Tuesday, 27 May 2008 3:12:08 AM(UTC)
adam PERTH
Does that make it less suss?
looks like AHX08313B
#403 Posted : Tuesday, 27 May 2008 3:16:48 AM(UTC)
Much less. But the chassis number itself still looks wierd.
adam PERTH Offline
#404 Posted : Tuesday, 27 May 2008 3:19:42 AM(UTC)
adam PERTH
Bryon hows your database going? approx how many vehicles do you have on file?
#405 Posted : Tuesday, 27 May 2008 4:09:37 AM(UTC)
Will count when I get a chance.
FastEHHolden Offline
#406 Posted : Friday, 30 May 2008 2:31:31 AM(UTC)
FastEHHolden
There is a HX ute on ebay..the owner claims its a sandman and sites www.sandmanowners.com/sa...ninfo-identification.htm as having the info to say it is one...even though his ute is a 3 speed and has the wrong trim code.
#407 Posted : Friday, 30 May 2008 2:32:32 AM(UTC)
FastEHHolden
#408 Posted : Friday, 30 May 2008 3:45:44 AM(UTC)
Ive already told him its not.
#409 Posted : Monday, 2 June 2008 8:22:51 AM(UTC)
hi
im looking to buy this panno
model HJ8WM70
body 192851A
trim 1899-60A
paint 567-15945
eng L32 trans M2O axle GU4
8M70RFJS24679J
5/76 GVW 1950 seat cap 2
bod BHJ16128M
chassis DHJ90630S
CURRENT ENG NUMBER 11T351528
black gts dash sandman logo steering wheel not original glove box door 9942959
double headlight front window less
could this be a factory sandman?
all help greatly appreciated
T-Dog
#410 Posted : Monday, 2 June 2008 5:19:57 PM(UTC)
There is a good chance it is, but it has had a chassis replacement at some stage. The current engine is a 308 which is also not original. Ill have a better look tonight. It is a pretty late HJ too.
#411 Posted : Tuesday, 3 June 2008 3:06:41 AM(UTC)
Nothing more to add. Tyre placard isnt original if its a Sandman or originally from a van for that matter. Twin front is not original for Sandman either but a BO6 (ambulance pack) did have a twin front. Does it have full length headlining and interior light switches on the doors?
Edited by user Tuesday, 3 June 2008 3:09:18 AM(UTC)  | Reason: Not specified
#412 Posted : Tuesday, 3 June 2008 7:29:51 AM(UTC)
#413 Posted : Tuesday, 3 June 2008 7:38:57 AM(UTC)
HI BYRON
THANKS FOR YOUR HELP
yes the van has the rear hoodlining clips
and the courtesy light switches for the doors
also gts guards
adam PERTH Offline
#414 Posted : Tuesday, 3 June 2008 10:37:14 AM(UTC)
adam PERTH
Bryon, were the B06 vans headlight wiring different to normal twin headlight?
i.e. to flash with siren on?
#415 Posted : Tuesday, 3 June 2008 5:45:25 PM(UTC)
Mine wasnt. They werent ambulances. They were an ambulance pack. Like the VK police cars.
#416 Posted : Tuesday, 3 June 2008 6:52:24 PM(UTC)
Hi Guys.
As Byron said they were ambulance packs, not ambulances.
Any special or extra wiring would be added as required by the guys that did the conversion to make it into an ambulance.
The twin headlight wiring is just stock Premier.
I own an HZ ambulance pack (One-tonner) & it has the stock Premier headlight wiring, including the relay that the HZ has for high beam.
HZute-efi-VS5L Offline
#417 Posted : Tuesday, 3 June 2008 10:58:47 PM(UTC)
HZute-efi-VS5L
dr terry. mate is there any chance you can send me a pic of how the stock standard twin headlight on a hz looks? im interested in seeing the relay, the fuse behind the booster and also the plugs on the headlight globes.
jason
www.stickthisdecals.com.au
optis000 Offline
#418 Posted : Wednesday, 4 June 2008 8:17:07 AM(UTC)
optis000
to byron rich do you have any history on one pano
build 12/1976
model HX8WM70
VIN AHX20580A
ENG QT958377
ID TAG 8M70TGL370089X
BODY 221357-A
TRIM 1916-67V
PAINT 568 17777
ENG L31
TRANS M41
AXLE GU4
I DO HAVE FIRST ORIGINAL REGO SLIP FROM NOEL GOULD HOLDEN AND FULL HISTORY AND WAS A ONE OWNER UNTIL RECENTLY I THOUGHT YOU MAY HAVE SEEN THIS VAN AND KNOW IF ITS A GENUINE SANDMAN FOR SURE AS I BELEVE IT IS IT HAS THE FULL HEAD LIGHNING INT LIGHT SWITCHES AND FACT AIR AND FULL CAMPER FOR REAR CAN YOU CONFIRM ANY OF THIS CARS HISTORY AT ALL ? CHEERS OPTIS000
Mr.Jones Offline
#419 Posted : Wednesday, 4 June 2008 8:47:26 AM(UTC)
Mr.Jones
Optis its definately not the original engine should be in the range QT820xxx to QT850xxx. Sounds a very nice van Papaya and a tail tent. Do you have the tyre placard might help with confirmation.
Leroy
Voltaire
#420 Posted : Wednesday, 4 June 2008 9:21:57 AM(UTC)
i have the original rego papers from new showing the correct engine no 100% with cash register print at bottem and the tyre placard is in the glove box i think it said 9942827 on bottem corner
This page was generated in 0.149 seconds.
