61 Pages«<2829303132>»
hx-sandman Offline
#581 Posted : Saturday, 30 August 2008 8:21:28 PM(UTC)
hx-sandman
34A is blue trim
#582 Posted : Saturday, 30 August 2008 11:54:34 PM(UTC)
Cheers mate, i found out the paint is Wedgewood (some description of blue?!)I was also curious about the Body No and the vin not matching. . ive read this does happen. . and if all 3 plates, do go together??
#583 Posted : Sunday, 31 August 2008 4:02:37 AM(UTC)
Was thanked: 602 time(s) in 569 post(s)
Adelaide PSN didnt appear on the BODY plate until mid-late HX so all OK.
#584 Posted : Sunday, 31 August 2008 7:53:44 AM(UTC)
Sweet. .Thanks
vanman Offline
#585 Posted : Tuesday, 2 September 2008 9:31:52 PM(UTC)
vanman
These are from my 2 sandmans...
Edited by user Wednesday, 3 September 2008 3:07:18 AM(UTC)  | Reason: Not specified
HZute-efi-VS5L Offline
#586 Posted : Wednesday, 3 September 2008 3:55:42 AM(UTC)
HZute-efi-VS5L
just a Q.
why hide a body number? because its the chassis number thats registed? Just interested =).
jason
www.stickthisdecals.com.au
ringfeder3 Offline
#587 Posted : Friday, 5 September 2008 5:07:12 AM(UTC)
ringfeder3
Gday Byron,
can you give me a pointer as to what the following numbers signify:
7/76 HX Coupe Utility.
L32/ M20/ GU4
GVW 1860 kgs
VIN AHX00958M
Seating Capacity: 2
Chassis: 8M880RFJS32660X
Tyre placard number: 99422827
Anything interesting?
Regards
Steve
#588 Posted : Friday, 5 September 2008 6:15:01 AM(UTC)
HX base model ute with 253. Possibly Sandman. Chassis and VIN are arse about.
#589 Posted : Friday, 5 September 2008 7:26:23 AM(UTC)
Gday byron just wanna do a check on these numbers please
model, HZ8WM70
body no, 469790-A
trim, 0924-67C
paint, 568-4500
eng,L32
trans, m40
rr axle, GU4
yr 11/79
gvm, 1950
seating, 2
long tag,8M70RKL469790Z
i was told it was either a sandman or a police pack if you could email me at [email protected] i would appreciate any help you can give me
cheers jimmy
#590 Posted : Friday, 5 September 2008 5:44:05 PM(UTC)
Its not a Sandman, its just a normal van with XU4 option (sedan tyres). To be a HZ XX7 Sandman after 12/77 the GVW should be 2000kg and the last HZ Sandman van was built around october 1979.
#591 Posted : Friday, 5 September 2008 5:53:23 PM(UTC)
Was thanked: 242 time(s) in 216 post(s)
Trim 924 (& paint 568-4500) is South Australian Police Blue, so it was probably a divi van.
Dr Terry.
#592 Posted : Saturday, 6 September 2008 11:13:40 PM(UTC)
Thanks for that, how would I confirm if it is, in fact, a Sandman from these numbers?
#593 Posted : Sunday, 7 September 2008 1:01:44 AM(UTC)
You cant from those numbers. If it has 18V trim code you can.
#594 Posted : Tuesday, 9 September 2008 5:07:16 AM(UTC)
OK, how about TRIM CODE 1890 - 18V and PAINT CODE 568 - 15953. No option codes. Tyre Placard 942991, my mistake.
#595 Posted : Tuesday, 9 September 2008 5:41:45 AM(UTC)
1890 is the paint code. 18V is slate black trim and on a base model HX ute/van sold new in Australia that spells Sandman.
#596 Posted : Saturday, 13 September 2008 11:38:36 PM(UTC)
Hi Byron,
you have previously confirmed my hx panelvan is a sandman. could you also let me know the original paint colour trim-1918 which is royal plum metalic paint-17773 which is bordeaux ???????
trim - 1918 18v
paint - 567 17773
thanks,
colin
adam PERTH Offline
#597 Posted : Sunday, 14 September 2008 1:19:36 AM(UTC)
adam PERTH
The GVm change from 2200 to 1950, on te brisbane build, is somewhere between:
BHJ 17525B to BHJ18142B.
only 600 cars different..
WANTED: QR 662xxx
#598 Posted : Tuesday, 16 September 2008 8:35:53 AM(UTC)
sandman project on ebay 3 seat 308 4speed floor, is it a genuine sandman?
Item number: 300258565933
#599 Posted : Tuesday, 16 September 2008 9:30:06 AM(UTC)
HZute-efi-VS5L
hi tony. answer is in your question. 3 seater = NO to sandman.....
HZpanelvanandsedan Offline
#600 Posted : Monday, 22 September 2008 5:11:31 AM(UTC)
HZpanelvanandsedan
My human error..
I had a HZ panel van which I ended up using for spares when I bought a better HZ panel van (less rusty with 253) and sent the first one off to get crushed :( ....anyway it had a GVW 2155, seating cap. 3, ENG L20, Trans m40, rraxle GV7, Model HZ8WM70 (or HZ8WN70 - this record is not clear), Built date 11-78, BHZ39279A, 8M70LJL433500Z, body no. 433500-A
I didnt take pictures but I have the details recorded in pen and also as a printed hard-copy, which been typed in a word document. My digital copy excluded the detail: Paint 568-8769 and the word TOP.
Strangely my first records (written in pen) indicate the following details as they appeared on the plates:
trim 1093-67C
paint 568-8769
568-0246
Also,
TOP
ENG L20
I definitely recall the word TOP being displayed exactly as shown above, as to the paint codes, well Im going off the records I noted down - perhaps its that recurring human error issue.
Jesse
(ecoimpact on oldholden.com)
This page was generated in 0.229 seconds.
