#1 Posted : Thursday, 26 May 2005 8:20:59 AM(UTC)
does anyone know a website that you can download carby setup specs for a 4.1 with weber dual throat
#2 Posted : Saturday, 28 May 2005 6:51:44 AM(UTC)
http://www.redlineweber....et_up_and_lean_best_.htm
try here for a basic setup
theres very little info on these webers for the xf
by the way they are a 34adm weber
........it took me ages just to find the bloody mixtur
#3 Posted : Sunday, 29 May 2005 10:21:35 PM(UTC)
thanks carlos i'll check it out
butterbox
#4 Posted : Tuesday, 7 June 2005 7:27:25 AM(UTC)
You need to do several things before you can even start to set it correctly. It has to be off the manifold to set the fast idle cam to specifications. You also need a good vacuum guage to set vacuum pull down on it before most other procedures can be done
