61 Pages«<4344454647>»
#881 Posted : Tuesday, 19 January 2010 8:04:01 AM(UTC)
Ill have a better look at my original brochure, but that looks like a HX dash. My guess is the HZ brochure cars were built during HX and hence had a HX dash. The red ute on the HX brochure was built during HJ production and has the wrong trim for a HX Sandman (it has 19V black not 18V slate).
Absinth Offline
#882 Posted : Tuesday, 19 January 2010 8:06:26 AM(UTC)
Absinth
Andrew, the HZ brochure actually has a HX Sandman pictured. They fitted a HZ console, painted the mirrors, fitted a twin headlight front + spoiler and stuck a RTS badge on the tailgate for the photo shoot.
Blocker Offline
#883 Posted : Tuesday, 19 January 2010 8:18:29 AM(UTC)
Blocker
I know what you mean. From Holdens perspective why build a full production car of the new series when they can represent the new model from existing stock.
I find this stuff intriguing.
HZute-efi-VS5L Offline
#884 Posted : Tuesday, 19 January 2010 8:53:07 AM(UTC)
HZute-efi-VS5L
The other thing with the dash facias are:
HJ black or silver had high beam in the warning lights below clock and a red warning light for the brakes. (failure and park brake in the one light)
HX had the high beam warning light in the speedo. and a red "brake" warning light and a blank red warning light.
HZ had the red "brake" warn light and also the "park brake" red warning light. High beam stayed in the speedo.
So white needle HJ and HX speedos are also different.
I have seen a few HJ GTS dash facias that were black with the high beam in the warning lights. (these a quite rare and hard to find) I may have a couple around here somewhere! Will have to go for a dig through my crap.........
www.stickthisdecals.com.au
Absinth Offline
#885 Posted : Tuesday, 19 January 2010 9:32:37 AM(UTC)
Absinth
HJ is easy to pick over HX even if the warning lights are missing. HJ had the infill panel over the left vent in Sandman and for GTS the infill panel was cut out with a saw for the vent to be fitted. In HX the dash was factory molded without the infill panel and also had an infill for the wiper switch hole for Sandman, on GTS they use the hole for the wiper dwell. This change and the warning light change would be the reason for the different parts numbers for HJ and HX GTS dashes.
If you look at the silver dash on the Ebay HJ you can see the infill panel still in place, although someone has drilled a hole in it to fit a aftermarket gauge.
#886 Posted : Tuesday, 19 January 2010 6:19:12 PM(UTC)
I just counted the Sandmans on the register. It reached 300 this morning with a ute sent to me by Adam. Keep em coming!
hx-sandman Offline
#887 Posted : Tuesday, 19 January 2010 11:33:58 PM(UTC)
hx-sandman
Have you got this one? Chamois ute
hx 01/77
ahx2210 a
g.v.w-1860kg
seat cap- 2
hx8wm80
body- 222836-a
trim-1887-18v
paint-568 15950
eng-L32
gbox-M20
diff- gv7
tire placard- 9942991
VIN tag missing
Nick
#888 Posted : Wednesday, 20 January 2010 1:18:04 AM(UTC)
Yes I have that one, but the chassis number is missing a digit and as you say the PSN is missing.
#889 Posted : Wednesday, 20 January 2010 4:13:54 AM(UTC)
HZute-efi-VS5L
Sorry I was going to send a disc with all the pic I have. Will do that tonight and send tomorrow.
Jason
Blocker Offline
#890 Posted : Wednesday, 20 January 2010 4:16:28 AM(UTC)
Blocker
I will not leave this up too long, I dont want it to clog the thread but I wanted to show/share what I am working on.
A web based color selector for the Sandman. The easy part is done, now on to the scripting.
They are only sample colors, I have 10 so far and many more to do. Once the scripts are written I will do a best attempt color match.
The big plan will be to add the decal color sets too.
Edited by user Wednesday, 3 February 2010 6:09:00 AM(UTC)  | Reason: Not specified
hzsandman Offline
#891 Posted : Wednesday, 20 January 2010 8:13:32 AM(UTC)
hzsandman
Love it Andrew
#892 Posted : Wednesday, 20 January 2010 8:17:39 AM(UTC)
you need to do it somehow like the FC boys do it, try this link;
http://www.fefcholden.or...hinfo/painter/index.html
#893 Posted : Monday, 25 January 2010 4:22:27 AM(UTC)
Hi, I am a new poster here. Just wondering if this hx ute is a sandman? 8WM80rgh9******
8WM80xr trim 1898-18v 10/76
Hope it is cause I just bought it.
#894 Posted : Monday, 25 January 2010 4:24:21 AM(UTC)
Oh meant to add M20 L32 GV7
Blocker Offline
#895 Posted : Monday, 25 January 2010 4:46:17 AM(UTC)
Blocker
Hi wbute, welcome to the forums.
Your numbers look good for a Sandman.
4.2lt 1977 built in Sydney. Trim code of 18v a helpful indicator too. Deauville Blue Metallic is a nice colour - DY2 decal (Orange, Bright Blue, Blue).
Congratulations :)
Edited by user Monday, 25 January 2010 4:54:28 AM(UTC)  | Reason: Not specified
#896 Posted : Monday, 25 January 2010 4:53:35 AM(UTC)
18V trim in a HX normally means Sandman. Send me the ID details and ill check them out for you.
#897 Posted : Monday, 25 January 2010 5:51:33 AM(UTC)
Stoked! Its has had its dash swapped and has a 6 and auto in it. But appears to be pretty rust free. Still has clutch pedal in though. Stoked! How do I contact you without putting all the numbers up?
#898 Posted : Monday, 25 January 2010 6:03:59 AM(UTC)
Email via here.
Blocker Offline
#899 Posted : Monday, 25 January 2010 6:06:20 AM(UTC)
Blocker
Hey wbute. Byron (HK1837) will have the no duff on the Sandman. Email him by clicking above his post, youll see a little envelope - its a email to member button.
Cheers.
#900 Posted : Monday, 25 January 2010 6:20:32 AM(UTC)
Worked it out I hope. This looks like a good site.
Guest (12)
This page was generated in 0.083 seconds.
