61 Pages«<4647484950>»
Mr.Jones Offline
#941 Posted : Wednesday, 3 February 2010 8:57:26 AM(UTC)
Mr.Jones
Very nice early sandy http://cgi.ebay.com.au/G...egoryZ2030QQcmdZViewItem
8M70REL286628J
HJ8WM70
126418A
1886 19V
15949
L32 M20 GU4
AHJ00041A
10/74 2200 2
May have been a release/press car??
Absinth I have a couple of other AHX after 2/77 so there definately out there.
Leroy
"Planet earth is the asylum to which the rest of the universe sends its lunatics"
Voltaire
Edited by user Wednesday, 3 February 2010 9:01:56 AM(UTC)  | Reason: Not specified
Voltaire
Absinth Offline
#942 Posted : Wednesday, 3 February 2010 11:13:27 AM(UTC)
Absinth
Pity about the sunroof.
#943 Posted : Wednesday, 3 February 2010 4:18:56 PM(UTC)
As far as I know there is no such thing as BHX on HX commercials. I have AHX until 8/77 from all assembly plants.
hx-sandman Offline
#944 Posted : Wednesday, 3 February 2010 7:52:03 PM(UTC)
hx-sandman
http://cgi.ebay.com.au/ws/eBayI...ewItem&item=140379666644
Tags only from HX Van for sale. Tsk tsk.
SANDMN Offline
#945 Posted : Wednesday, 3 February 2010 11:15:48 PM(UTC)
SANDMN
should get them framed and hung on the wall so a van cant be bodgied up
n.j.Burr
Blocker Offline
#946 Posted : Thursday, 4 February 2010 12:04:52 AM(UTC)
Blocker
Body Plate
HQ80270
319474B
1868 30B
567 15335
L31 - M21 - GV2
No XX7 stamp.
VIN
8M70TDH319747Q
ADR
6/74 EHQ64502B
GVW 4850lbs Seating Cap 2
[url="http://www.mysandman.com.au/"][/url]
Edited by user Thursday, 4 February 2010 12:05:32 AM(UTC)  | Reason: Not specified
#947 Posted : Saturday, 6 February 2010 10:46:20 PM(UTC)
Originally posted by Absinth
HJ is easy to pick over HX even if the warning lights are missing. HJ had the infill panel over the left vent in Sandman and for GTS the infill panel was cut out with a saw for the vent to be fitted. In HX the dash was factory molded without the infill panel and also had an infill for the wiper switch hole for Sandman, on GTS they use the hole for the wiper dwell. This change and the warning light change would be the reason for the different parts numbers for HJ and HX GTS dashes.
If you look at the silver dash on the Ebay HJ you can see the infill panel still in place, although someone has drilled a hole in it to fit a aftermarket gauge.
Out of interest, I found an immaculate and original fully loaded HJ Premier the other day. It is a 1974 build HJ, and as such has a silver type 4 dash and it looks wierd with the woodgrain glovebox and centre console. Obviously early on there was only the one dash as youd think if there was going to be any different dash itd be in the Premier and LS to remove this woodgrain and silver combo (which obviously was fixed later). This reflects the early catalogue info too.
adam PERTH Offline
#948 Posted : Sunday, 7 February 2010 2:28:59 PM(UTC)
adam PERTH
the earliest HJ sandman???
#000041 out of adelaide
http://cgi.ebay.com.au/G...Cars?hash=item2a0450bfd5
WANTED:
-2 14 x 9.25 CSA style Centrelines.
-2 x 15 x 8 Dragway centrelines
adam PERTH Offline
#949 Posted : Sunday, 7 February 2010 2:34:20 PM(UTC)
adam PERTH
ohttp://cgi.ebay.com.au/H...Cars?hash=item3ca9ef1da4
the GVM on this one looks odd, this one looks to end in 00? does it read 1800 kg???
WANTED:
adam PERTH Offline
#950 Posted : Sunday, 7 February 2010 2:36:36 PM(UTC)
adam PERTH
comments sought on this HJ sandman tailgate decal..
http://www.auctiva.com/h...0,0,0,0,0,0,0,0&format=0
WANTED:
Absinth Offline
#951 Posted : Sunday, 7 February 2010 2:59:13 PM(UTC)
Absinth
Tailgate decal looks fine Adam, what do you think is wrong with it?
You need to shorten those urls mate.
HZute-efi-VS5L Offline
#952 Posted : Sunday, 7 February 2010 7:42:01 PM(UTC)
HZute-efi-VS5L
Correct Adam. It has some errors.
At a guess Im guessing its one of the vinyl cut ones on the market.
Not the screen printed ones.
My kits as where the sandman_decals(ebay) blokes kits (when he had them) when matched from NOS samples.
The issue with it is the spacings of between each of the boxes.
There is the centre black box. Then the nothing box where the paint shows.
Then the thicker of the two black boxes. The spacing between the solid centre
black box and the thicker of the two black outline box is not correct.
It should be about half that spacing.
Jason
www.stickthisdecals.com.au
Sunstater Offline
#953 Posted : Monday, 8 February 2010 6:11:29 AM(UTC)
Sunstater
Byron, please find details from my van for register. Had it only since 2002. From what is left and your monaro pages info it seems to be 95% chancer. Drivetrain chaged. I would like your ideas please. Rick.
ADR PLATE:
HOLDEN HX PANEL VAN
11/76 gvw 1950 ahx 16625A
SEATING CAP: 2
MODEL: HX8W M 70
BODY NO. 215804-A
TRIM: 1918-60A
PAINT: 567-17774
ENG: L31 TRANS:M21 RRAXLE GV4
ID PLATE: 8M70TGL36535X
Thanks Very Much.
#954 Posted : Monday, 8 February 2010 6:31:21 AM(UTC)
Id be surprised if it isnt. It could be an XU4 but most likely XX7. Check for headlining rear strip and interior light switches in door jam and/or wiring for them.
#955 Posted : Tuesday, 9 February 2010 10:48:58 PM(UTC)
WANTED:
Sure does. Another little bit of info that has only just crept out of the woodwork, with 3 x 6cyl HJ and HX XX7s in the past 2 weeks.
#956 Posted : Tuesday, 9 February 2010 10:53:57 PM(UTC)
Originally posted by Blocker
Body Plate
HQ80270
319474B
1868 30B
567 15335
L31 - M21 - GV2
No XX7 stamp.
VIN
8M70TDH319747Q
ADR
6/74 EHQ64502B
Yeah, I already had it recorded. The BODY number should be 319747 though. Another one of those wierd Acacia Ridge "Sandmans" without XX7. Ive only recorded one of them that cannot be a Sandman (ie metallic paint without XX7) and it was a 3 seater. Rest are all very much Sandman-like. There are 10 of them recorded.
CrustyHK Offline
#957 Posted : Thursday, 11 February 2010 4:44:45 AM(UTC)
CrustyHK
Hi Byron, or anyone else who could enlighten me on these numbers
MOD-HX8WM70
BOD-236624-A
TRIM-1886-18V
PAINT-568-15949
L32 M20 CV7
6/77
1950KG
AHX05152M
SEAT-2
Pete
#958 Posted : Thursday, 11 February 2010 4:58:23 AM(UTC)
Very much a HX XX7 Sandman van. Not much else to tell, apart from 253 4spd with 3.55 diff. 1886 is Absinth yellow and 18V is slate black trim.
CrustyHK Offline
#959 Posted : Thursday, 11 February 2010 5:39:30 AM(UTC)
CrustyHK
Thanks Byron
Its rusty in some nasty places and with windows in the back and a sunroof it really needs a complete top on it so not a job for the feint hearted. Would be a nice one when done though
Pete
#960 Posted : Thursday, 11 February 2010 5:46:15 AM(UTC)
here it is in the flesh
[img][/img]
[img][/img]
Edited by user Thursday, 11 February 2010 5:47:48 AM(UTC)  | Reason: Not specified
Guest (19)
This page was generated in 0.142 seconds.
