#1 Posted : Sunday, 29 May 2005 6:35:52 AM(UTC)
Is it possible to use VC commodore front disc,s on a HT front end,also is the standard HT disc brake booster able to cope with a VC disc brake diff.Any info would be appreciated,Rick308.
#2 Posted : Sunday, 29 May 2005 5:48:18 PM(UTC)
Hi rick308.
The disc rotor will go straight on, because the bearings are the same. Unfortuneately the caliper won't line up on the HT stub.
Would be much easier to use HQ-WB brakes, everything fits, but you then use HQ-WB wheels not Commodore.
Dr
#3 Posted : Sunday, 29 May 2005 7:38:05 PM(UTC)
For the diff question I believe the HT booster and master cylinder will have no problems with the Commodore rear calipers. You just need to use the correct master cylinder and modify it accordingly to operate the rear discs - talk to a brake specialist ab
#4 Posted : Sunday, 29 May 2005 11:25:39 PM(UTC)
Not sure about the HT boosters, but the only difference between the HZ and WB boosters is the front half of the booster on the WB has the mounts for the master cylinder at a different angle to suit the different master cylinder used on the WB model.
#5 Posted : Tuesday, 31 May 2005 6:56:05 AM(UTC)
Thanks guys most helpful,now I only have to decide which stud pattern to use,cheers.
#6 Posted : Tuesday, 31 May 2005 8:48:19 AM(UTC)
Hi Guys.
The only reason I didn't mention stud pattern is that the car was going to have that anyway.
HQ fronts with HT rears or Commodore fronts with HT rears, they're still different, front to rear.
As rick308 said, he is yet to pick a stud pat
This page was generated in 0.140 seconds.
