RussVRute Offline
#1 Posted : Tuesday, 31 May 2005 7:53:00 AM(UTC)
RussVRute
G'day All,
Could somebody tell me excactly where to put the premier badges on HQ front guards, (e.g. 3" from the bottom in the centre etc.) as I have a set I would like to put on. Thanks.
Russ
trubluhq Offline
#2 Posted : Tuesday, 31 May 2005 7:58:53 AM(UTC)
trubluhq
Isnt it the same place as the Kingy badge ? It should be.
John
RussVRute Offline
#3 Posted : Tuesday, 31 May 2005 8:06:42 AM(UTC)
RussVRute
Yeah thanks for the reply, but mine has no badges so I cant just swap. Cheers. Russ.
#4 Posted : Tuesday, 31 May 2005 9:01:14 AM(UTC)
Hi Russ,
I'll measure where the holes are on my front guards (tomorrow, in daylight) and let you know during the day.
Cheers...Dave
#5 Posted : Tuesday, 31 May 2005 9:10:21 PM(UTC)
Hi Russ,
On my ute, the front hole for the badge is 21 mm back from the front edge of the guard and 64 mm down from the centre of the belt line "hump".
HTH.
Cheers...Dave
#6 Posted : Tuesday, 31 May 2005 11:45:15 PM(UTC)
I should have mentioned that both measurements are taken with the tape measure straight...not following the line of the panel.
Cheers...Dave
RussVRute Offline
#7 Posted : Wednesday, 1 June 2005 4:43:18 AM(UTC)
RussVRute
Thanks Dave, you have been a tremendous help, I appreciate it.
Russ
#8 Posted : Wednesday, 1 June 2005 4:50:06 AM(UTC)
No worries mate...you're welcome.
Cheers...Dave
RussVRute Offline
#9 Posted : Sunday, 5 June 2005 8:05:34 AM(UTC)
RussVRute
G'day Dave, I forgot to ask how they are secured on the guards, they have 3 pins on the back of each badge, but they arent threaded or anything, so are they held on by a speed nut type of deal or something ?
cheers Russ.
#10 Posted : Sunday, 5 June 2005 8:21:01 AM(UTC)
Hi Russ,
Some people use a special retaining clip on each of the pins. It looks like a washer with a couple of tabs going into the centre of the hole (or an "H" shaped cut out of the disc...The proper one looks like a washer and thin nut welded togethe
