will a front window off a HK sedan fit a HK ute???
I know the doors are interchangable, so I'm 95% sure the windows are too.
Cheers...Dave
yep...hk ht hg...all the same.. |
Hi Guys.
Do you mean windscreen or front door wind-up window.
The wind-up windows are the same for all HK/HT/HG except Monaro.
There a 3 types of windscreen, square corners at the top, round corners at the top & Monaro.
Dr Terry. |
Good point Dr Terry, I assumed driver's side door window for some reason.
Cheers...Dave
sorry it is the front windscreen im asking about for a HK belmont ute
Hi Guys.
Yes, HK Kingswood sedan windscreen will fit any HK/HT/HG ute.
Dr Terry. |
Joined: 2/03/2005(UTC) Posts: 451  ![Australia Australia]() Was thanked: 15 time(s) in 14 post(s)
With the price of windscreens it's almost worth considering new glass and rubber.It depends on the value of the car & the work but new glass really makes the view much better.
if you have it insured it's usually covered by your policy too...
