#1 Posted : Wednesday, 1 June 2005 6:25:29 AM(UTC)
One of the glass lens on the front headlight has condensation/wetness inside.
Apparently it only needs to be removed and dryed and then replaced. How easy is this and what will i need before i pull it apart... It would be just like me to pull it apart and not get it back together again... Is this something I can do? Or is it permanantly sealed?
#2 Posted : Wednesday, 1 June 2005 6:37:41 AM(UTC)
most of the time if there is water in them there is either a chip/crack in them and the only real way to fix them is to replace them or you could try some silastic.if you just clean it out it will get more in it again.not sure about au lights as i havn't
