Can anybody tell me the paint code for "barbados green" or a site where this code mite be listed ? Regards: Gav PS: i have done a search of the net 1st before asking too thanks
do you have hq gts stuff 4 me ?????
Gav,
If no one else can get it soon I will get it when I get home. Off my ID plate.
Cheers, john
thank you John
the paint code is 15827,go to monaro club of victoria on the web,and it lists and the paint codes,good luck.gts082
The guys are correct 568-15827.
John
excellent :) thank you both for that ! Regards: Gav
need paint code for HK MONARO GTS PLEASE.......
Deano,
It may help if you tell us what colour you need the code for?
Warwick Yellow is either 585-10846 or 568-10846.
From what I have read, I believe the prefix for this colour above is correct.
The type of paint changed during the HK series and therefore the prefix changed.
Someone with more knowledge may like t
Paint code for Barbados Green is 1877. You only have to be in front at the end of the race. Edited by user Tuesday, 28 March 2006 9:35:32 PM(UTC)
| Reason: Not specified |
You only have to be in front at the end of the race. |
Hi JBM.
1877 is the GM-H Exterior Trim Combination number.
The paint number (or the Dulux shade number) on the 'Paint' line, on the body plate is 15827.
Dr Terry |
Is the 3 digit no in front of that 567 for metallic and 568 for solid or non metallic? You only have to be in front at the end of the race. Edited by user Wednesday, 29 March 2006 8:32:49 PM(UTC)
Hi guys, i have a 1971 HQ sedan (308) I've been trying to find out if the paint colour is correct. It's kinda Lime Green. The paint code is ... 568-13137 and the top is ... 568-13134. At the moment, the roof is white. Or any help on where to find out woul
Hi karrots.
The name of the green paint is 'Olive Green' & the roof colour is 'Glacier White'.
Could you post your trim code please.
Dr Terry. |
Thanks Dr Terry... the trim code is 1310-16E i'm fairly sure it's E.. looks a little like C
