#1 Posted : Friday, 10 June 2005 3:42:29 PM(UTC)
Hi everyone, recently I stupidly let my battery go dead flat. Since I put the new battery in my airbag warning light won't go out. Is there a way of fixing this other than taking my car to a professional?? I have been told it is the computer that needs re setting, can this be done at home or is it a specialised job?? thanks in advance
#2 Posted : Thursday, 16 June 2005 4:48:22 AM(UTC)
Try to remove SRS fuse in fuse panel - with key off - for 20 secs. Refit and start car.
#3 Posted : Sunday, 3 July 2005 3:51:08 PM(UTC)
Thanks murrautoserv
Will give it a go and let you know. Anything is worth a try, that won't cost the earth!
#4 Posted : Wednesday, 6 July 2005 7:37:59 AM(UTC)
YOU HAVE TO CLEAR THE AIRBAG CODE OUT OF THE MODULE. TURN THE IGNITION ON AND LET THE LIGHT FLASH OUT THE CODE AT LEAST ONCE. THEN YOU NEED TO GO TO THE DIAGNOSTIC CONNECTOR. IT IS LOCATED IN WITH THE FUSE PANEL. THERE IS TWO ROWS OF PINS. YOU NEED TO SHO
