Im putting second trimatic in to my hq tonner. and the one i got i think is out of a torana. it fits all and bolts up fine but won the rear on the other side is some sort i electrical connection i think like a pressure or oil temo gauge sender. has any one seen these and know what its for. Also with the Torque Conveter with it all the way in it rubs on the bell housing is this right. thanks chris
Hi shrek.
The switch you are referring to is part of the pollution vacuum advance on a post July '76 car, obviously it was out of one of these cars. Just ignore it, you don't need to use it for your car.
The torque converter's position relies on the |
