i was wondering if i could replace my hq 1 tonner cab for a hj 1 tonner cab? are there any problems fitting the hj cab on the hq chassis? the hq cab has a fair amount of rust and ive found a good hj cab to replace it with,is this a good option or should i just spend my time fixing the rust spots in the hq cab? cheers
Thanks: 1 times Was thanked: 635 time(s) in 597 post(s)
As long as the HJ cab was not an ambulance pack the cabs will be almost identical. A HJ ambulance pack has HJ Premier front panels hence the cowl section in front of the windsceen has the body lines to match the HJ bonnet, whereas a 'normal' HJ tonner has |
