2 Pages<12
#21 Posted : Sunday, 24 January 2010 7:27:45 PM(UTC)
Originally posted by Adj
I ran 406 sbc in hk gts best both worlds sb weight with bb power if put gd higher compression heads. 400 bores simesed so they can run hot but 4 core took care of that. Always thought 4 inch block with 400 crank was 383 400 block with 350 crank equals 377
4" bore with 400 crank is 377ci. It becomes 383ci when bored +0.030". Most people call them 383 though, as are stroked 308s called 355 when the capacity is 350ci (5.7L) as HSV built them. I do understand the 383 thing as its not a factory capacity, but 355 is blatantly wrong otherwise every 30 thou up 202 should be a 205, or 308 should be 312 or whatever it is.
Adj Offline
#22 Posted : Sunday, 24 January 2010 8:31:53 PM(UTC)
Adj
Thanks hk1837 checked my maths was going off 30 thou blocks
ramerenz Offline
#23 Posted : Friday, 4 February 2011 2:34:47 AM(UTC)
ramerenz
is it really possible to create a project like that? chev put into hg monaro? sounds interesting. i think i gonna let to try it.
____________ [url="http://www.carparts.com/Hood-Scoops/600023145.car"]hood scoops[/url]
Edited by user Friday, 4 February 2011 2:35:29 AM(UTC)  | Reason: Not specified
greenhj Offline
#24 Posted : Friday, 4 February 2011 3:45:09 AM(UTC)
greenhj
Originally posted by HK1837 ... but 355 is blatantly wrong...
Ever tried finding 4.00" pistons or a holden block that will take 4.00" pistons after doing 11ty million miles?
most of the engine guys advertise them as 355 because they are taken straight to +0.030 so OTS and readily available chev pistons can be used and most of the kits are supplied with +0.030" for the same reason.
so while youre correct, your kinda not as well lol.
11.38@117mph
will go quicker
11.34@121mph
went quicker and faster, just not quick enough.
now being rebuilt with less cam, much less comp, and a turbo.
Simmo Offline
#25 Posted : Tuesday, 8 February 2011 11:33:51 AM(UTC)
Simmo
A mob in Castlemaine makes 2" BBC into HKTG headers that work with standard steering box. I bought a set for a BBC dyno run. Plan to put them into my HK with a centrifugally blown 454 at a later date. There are a couple of low rise BBC manifolds that should keep things under the hood.
2 Pages<12
