redvk07 Offline
#1 Posted : Monday, 28 July 2008 6:37:00 PM(UTC)
redvk07
Project Turbo 6
Project Turbo 6 is a major project underway at Farr Faster Race Engineering in central Victoria. The project is 'building a Turbocharged Holden 6 Cyl. black motor' in a VK Commodore running on straight LPG. The main objective of this build is come up with a well designed Turbo kit for the early Holden 6 Cyl. engine. For the full objective's of the build visit www.farrfaster.com.au. Please excuse the website at the moment as it is only new and still under construction.
I will be posting photos along the way of the build and updating everyone of where we are with the project.
The SPECS to date are as below.
Standard Block (but grout filled to the bottom of the water pump)
.030" up
Top and bottom ARP stud kits
Standard head (reco'd)
Chambers laid back to reduce compression
Bigger valve springs
Yella Terra Adjustable roller rockers
ACL Race series head gasket
ACL Unleaded pistons
Standard EFI cam
Mechanical lifters
Standard rods
Standard Blue/Black motor crank
Opened and radiuses oil ways
Standard sump with small baffle welded in
Larger o/d oil pick up
Complete re-design of cooling system
Blue/Black motor exhaust manifold
VK EFI intake manifold
Gas Research Carby
New Turbo
Small front mount Intercooler
Crane cams HI6 Ignition
Autronics computer (for ignition timing only)
Gearbox. Full manual Tri-matic
Stall. 2500rpm
Diff. Standard for now (till she breaks)
Please feel free to hit me with any suggestions or question you might have with any of this.
REDVK07
REDVK07
boom Offline
#2 Posted : Monday, 4 August 2008 6:05:53 AM(UTC)
boom
what turbo are you using? may i suggest a T04b, or if going new, a Garrett GT3540r with a T3 flange.
In cubes we trust.
#3 Posted : Tuesday, 5 August 2008 6:27:34 AM(UTC)
In cubes we trust.
We are going with a new turbo, it has been all sized by ROTA-MASTER in Melb. It has .63 A/R Exhaust housing and a .50 A/R comp housing. I am not 100% on those numbers but fairly sure. It has a T3 flange.
vyturbo Offline
#4 Posted : Friday, 8 August 2008 9:36:11 PM(UTC)
vyturbo
Hey, i checked out your website. Car is gonna be great. Any more updates? Ball park figures what kinda power you hoping for? Man that turbo in the pics on your website looks massive, it looks bigger than .5 A/R compressor housing and .63 A/R exhaust housing. Anyway, good luck with it all.
redvk07 Offline
#5 Posted : Saturday, 9 August 2008 10:29:05 AM(UTC)
redvk07
Nah thats the sizwe mate. Its getting closer to finished now.
Ball park figures...
Well with the stage 1 Factory cam set-up we are hoping for 150hp upwards..(hoping) LOL
And I have some pics..
Not sure how to put them up??
Can anyone help??
REDVK07
REDVK07
redvk07 Offline
#6 Posted : Thursday, 14 August 2008 7:09:02 AM(UTC)
redvk07
hey everyone,
Link to a video we made. http://www.youtube.com/watch?v=z3zIjok9WTE
REDVK07
REDVK07
Mr Void Offline
#7 Posted : Monday, 1 September 2008 6:05:05 AM(UTC)
Mr Void
Haha! That vid was great!!
XR6 turbos are 0.5 comp AR but 1.06 rear - I always thought they would do well on a 202 but I would have gone with the 0.86 rear. The 0.63 rear would spool so quick (fun and games!), presuming thats what you are using...
Loving this build - well done to yas. Im really looking forward to the 2nd 3rd and 4th stages!!!!
___________________
Why are you reading this, you should be looking up there^^
Joetech Tonner - coming soon!
___________________
