les Offline
#1 Posted : Tuesday, 5 July 2005 12:52:40 AM(UTC)
les
I need some help with HQ GTS dash lenses it would appear that the tacho and speedo lenses are the same and that the GTS only had Flexdrive speedo and tacho is this correct?
Also are the lenses on the fuel / oil the same as temp / bat and is there only one type of each ie Flexdrive?
Les
#2 Posted : Sunday, 10 July 2005 1:20:28 AM(UTC)
To the best of my knowledge ( many moons since the GTS dash went into the Q ) the speedo and tacho lenses interchange. The temp/amps lens is the same as the fuel/oil. From memory, the clock lens is unique.
Webby........SACK COLIN BOND !
This page was generated in 0.080 seconds.
