7 Pages«<34567>
#81 Posted : Saturday, 28 February 2009 3:56:33 AM(UTC)
bump ,just to keep it going!
Jim in adelaide
The Yeti Offline
#82 Posted : Saturday, 28 February 2009 4:13:27 PM(UTC)
The Yeti
Originally posted by booger
Go learn how to do the shopping and everytime you pay for it get an extra $20 out to go toward your project. The Mrs will never know.
Skim skim skim if she dont let you have too much cash and
If you got a screw to put in a tight situation use this trick.
Put your screw driver on the magnet of an old speaker to magnitize the screw driver so the screw sticks to it
http://boogermobile.blogspot.com/
This is Called the yeti accounting system, I am now on my second build with this system and going well, I also offer to get take away. and taking a sandwich for lunch and hiting the Mrs up for lunch money also ads a little bonus to the account ;-)
See The Yetis Chev build at
http://www.ozrodders.com...rd/viewtopic.php?t=17919
Macquarie Towns Hot Rod Clubs new website http://www.hotrodclub.info
See The Yeti's Chev build at
lxtoranahzute Offline
#83 Posted : Monday, 2 March 2009 3:18:17 AM(UTC)
lxtoranahzute
Just read (doors wont shut topic)Verry funny.Research far out ideas and have all materials and knowledge ready before you cut the roof of your car/monaro
#84 Posted : Monday, 2 March 2009 3:25:00 AM(UTC)
surely that thread is a joke
if it wasnt for the last minute id get nothing done
#85 Posted : Monday, 2 March 2009 3:29:36 AM(UTC)
money is always the biggest issue in a project, i used "the yeti technique" and it helped heaps
search swap meets and garage sales for parts, and buy bits when you see them cheap not when you have to have them or you will have to pay more to get what you want
#86 Posted : Monday, 2 March 2009 3:30:31 AM(UTC)
lxtoranahzute
Ya never know,Some of the worst ideas come from an idiot and theirs plenty of idiots arround
#87 Posted : Monday, 2 March 2009 3:36:39 AM(UTC)
very true
#88 Posted : Monday, 2 March 2009 4:54:08 AM(UTC)
while on the subject of stupid people, check this out http://www.pirate4x4.com.../showthread.php?t=763645
#89 Posted : Monday, 2 March 2009 4:56:16 AM(UTC)
and this one http://www.audiforums.co...m/showthread.php?t=80267
some people make you wonder
this guy just made me laugh
Premier 350 Offline
#90 Posted : Friday, 6 March 2009 1:08:37 PM(UTC)
Premier 350
Block/cover any "holes" eg end of fuel, brake lines etc, to keep the
hornets from building their nests in em.
When painting cyl heads, plug the ports up..... paint on exhaust valve stems can cause a sticking then burnt valve. So my engine rebuilder claims. Sounds plausable to me.
Australia.... marcos ambrose free since 2005
#91 Posted : Friday, 6 March 2009 6:46:34 PM(UTC)
Priceless !!
Anthony333 Offline
#92 Posted : Monday, 23 March 2009 6:33:22 AM(UTC)
Anthony333
For hard to reach spots that you cant see, to know where to put your bolt in or out etc, i use my small digital camera, take a photo, have a look and then continue, works great in a dark place too like underneath your vehicle... also, when i work on something, i always put all bolts in to a piece of cardboard or styro foam to keep them in order for re assembly.
Cheers, Ant
#93 Posted : Monday, 23 March 2009 10:51:36 AM(UTC)
when assembling things like carbies and gearboxes that have small springs and ball bearings to fall out and get lost pack them in with axle grease. the grease will dissolve in the petrol or oil and the bits will stay in place.
also keep el cheapo tool kit to loan the cheapskate mates who come around to borrow yours. when they break it they will replace it with good stuff out of embarassment and if they dont replace it you are not much worse off and you know not to lend your tools to them again.
#94 Posted : Thursday, 12 November 2009 5:37:48 AM(UTC)
bump,
Jim in Adelaide
jabba Offline
#95 Posted : Friday, 13 November 2009 9:09:32 PM(UTC)
jabba
Just found a doozy. When having a 350 chev reconditioned, upon reassembling engine had monster oil leak. After much investigation and cursing pulling apart and putting back together, I discovered a "feature" of the sb chev. On the front of the block beside the fuel pump are tow empty bolt holes. The top one goes through the block into the Fuel Pump pushrod hole (so you can put a bolt through to hold the pushrod in place when removing / replacing fuel pump). When the block comes back from reco, they usually take this bolt out for cleaning. If you dont put a (short) bolt back in the hole, all of the oil falls out. It falls out in such a way as to pretend to be a whole bunch of other leaks.
#96 Posted : Friday, 13 November 2009 9:28:39 PM(UTC)
Win lottery and pay someone to do it all for you.....
Oh no sorry - thats half the fun...
#97 Posted : Friday, 13 November 2009 11:15:38 PM(UTC)
These bolt holes at the front of a SBC are also used for the engine mounts on early models (55-56-57 etc.).
ghg308 Offline
#98 Posted : Saturday, 14 November 2009 11:59:28 PM(UTC)
ghg308
when rebuilding a set of old brakes that arent in use anymore attach your grease gun to the brake hose inlet and pump in the grease to remove the piston without damaging it, plenty of people try to get the pistons out withhammers , screwdrivers, multigrips etc and cock them up, just remember to clean all parts until they are spotless before the rebuild
#99 Posted : Sunday, 15 November 2009 4:16:00 AM(UTC)
Take digital photos before the dismantlement of anything complex,as stated above .Ive done that before.And buy a book because there is always stuff in there you dont know ,or you can reference back to it.
Jim in Adelaide
#100 Posted : Sunday, 15 November 2009 4:19:03 AM(UTC)
ask heaps of questions, a stupid question is one that is never asked
Guest (33)
7 Pages«<34567>
This page was generated in 0.065 seconds.
