slobey Offline
#1 Posted : Monday, 23 February 2009 1:54:43 AM(UTC)
slobey
Hi all,
This is my current ride:
[img][/img]
Its a HJ GTS4 with factory sunroof.
It currently has a WB Caprice front clip on, I'll be picking up some GTS guards in a couple of weeks and then I can start changing it over.
It's running a 253/aussie 4speed/sally diff
There's not a lot of rust in her just a couple of bits that need tidying up a bit.
Cheers Quent
Edited by user Thursday, 14 May 2009 7:14:09 AM(UTC)  | Reason: Not specified
slobey Offline
#2 Posted : Monday, 23 February 2009 2:05:52 AM(UTC)
slobey
Hi all,
This is what the car currently looks like:
[img][/img]
[img][/img]
Ive put the hornetless bonnet on, added some cheap mags from a mate and redone the front suspension (shocks, ball joints and bushes).
Plans are to change the front end asap, add gts spoilers (front & back) and add the correct gts blackouts.
Long term plans are to replace the driveline with a 454/T400/9 inch and have some fun down at Kwinana
Ill post any updates as they happen.
Cheers quent
PS any idea how to add pics in rather than links?
Edited by user Thursday, 14 May 2009 7:17:05 AM(UTC)  | Reason: Not specified
playwme Offline
#3 Posted : Wednesday, 25 February 2009 7:51:55 AM(UTC)
playwme
Looks 10 times better without the scoop and changing the front end should improve it even more. The WB fronts really dont suit the sedans at all.
To add an image use the image button in the format section (4th from right) and then put the web address of the photo between the 2 img brackets that pop up.
Edited by user Wednesday, 25 February 2009 7:54:35 AM(UTC)  | Reason: Not specified
slobey Offline
#4 Posted : Wednesday, 15 April 2009 6:29:36 AM(UTC)
slobey
[/img]
Picked up these on the weekend from a bloke who used to work for me. Theyre probably in as good nick as any Ive seen before so im stoked.
Ive got all the bits i need for the front end swap over. Now its time to start rubbing them back.
Edited by user Thursday, 14 May 2009 7:07:44 AM(UTC)  | Reason: Not specified
slobey Offline
#5 Posted : Tuesday, 12 May 2009 6:19:49 AM(UTC)
slobey
Hi all,
[img][/img]
just got my guards back from the soda blasters and Im pretty impressed with how it all came up (apart from the dent on the trailer ride home). My youngest is just as excited as me lol.
Who ever had them before me did everything right, even lead filled the aerial hole
Radiator support and inner guards are at the powdercoaters so in the next few weeks Ill prime these and start saving for a bit of paint.
Stoked Quent
Edited by user Thursday, 14 May 2009 7:08:38 AM(UTC)  | Reason: Not specified
vintageholden Offline
#6 Posted : Wednesday, 13 May 2009 10:51:21 AM(UTC)
vintageholden
keith here whats the hight of the bonnet scoop
a quick question
i have a wb and changed the front to premier( the one from you )
now the bonnet doesnt line up????
are they different??
Edited by user Wednesday, 13 May 2009 10:53:09 AM(UTC)  | Reason: Not specified
adam PERTH Offline
#7 Posted : Thursday, 14 May 2009 12:14:02 AM(UTC)
adam PERTH
You are a member of these groups:: Registered, Veteran
Yes. HQ Cowl / plenium to bonnet different to HJ-WB by about 2 inches.
the bonnet lines are different.
I brought that WB caprice front clip off slobey, i will measure it 4 you.
also, to put WB front clip on HQ-Z, you must take a bit out of the front of your chassis rails for the rad support to fit.
WANTED:
-2 14 x 9.25 CSA style Centrelines.
-2 x 15 x 8 Dragway centrelines
Edited by user Thursday, 14 May 2009 12:21:15 AM(UTC)  | Reason: Not specified
#8 Posted : Thursday, 14 May 2009 4:34:34 AM(UTC)
vintageholden
bonnet wont shut....
slobey Offline
#9 Posted : Thursday, 14 May 2009 6:17:19 AM(UTC)
slobey
Thats a bit odd keith, HJ-WB bonnets are pretty much the same I thought
Quent
slobey Offline
#10 Posted : Thursday, 14 May 2009 6:33:15 AM(UTC)
slobey
I picked up the inner guards and radiator support from the powdercoater today. They came up very nice :-)
Check out the guard, you can see my reflection taking the photo!
[img][/img]
[img][/img]
Edited by user Thursday, 14 May 2009 7:10:17 AM(UTC)  | Reason: Not specified
#11 Posted : Thursday, 14 May 2009 7:13:19 AM(UTC)
vintageholden
had to weld in the plate for the bonnet catch as it was cut off....
slobey Offline
#12 Posted : Sunday, 17 May 2009 4:43:17 AM(UTC)
slobey
I got bored today and did a trial fit of my soda blasted and powdercoated panels etc.
Engine bay:
72wallaby Offline
#13 Posted : Monday, 18 May 2009 11:29:36 PM(UTC)
72wallaby
Nice one Quent,
Shes coming along well. Did you use stripped bare for your soda blasting?
slobey Offline
#14 Posted : Tuesday, 19 May 2009 6:47:22 AM(UTC)
slobey
Originally posted by 72wallaby
Nice one Quent,
Nah I used a bloke from mandurah whos a mate of a mate. He did a top notch job. Im getting motivated again now :-)
Quent
bronsonHX Offline
#15 Posted : Thursday, 28 May 2009 8:44:00 AM(UTC)
bronsonHX
looks a million bucks with the GTS front and mags compared to the WB front and stockies.
slobey Offline
#16 Posted : Sunday, 23 August 2009 7:41:46 AM(UTC)
slobey
Hi all,
Heres some updated pics. The front has been sprayed and goes in on tuesday to get the paint blended into the restof the car and to have the blackouts done:
slobey Offline
#17 Posted : Tuesday, 1 September 2009 4:31:29 AM(UTC)
slobey
Flutes blacked out
Guest (5)
