#1 Posted : Monday, 11 July 2005 6:31:59 PM(UTC)
This car was formally a 202, now fitted with a hot 308. I originally tried to maintain the 6 cylinder booster but suffered from bad fade.
I have now upgraded to the V8 booster and master cylinder. I picked this up second hand and when i originally fitted it, the pedal was extremely spongy and i had basically no brake pressure. Also a lot of air in the lines, took ages to bleed the system.
So i went and bought a brand new master cylinder and fitted it over the weekend, this time the system bled nicely and the pedal was firm. However when i got the car out onto the street the pedal was rock hard, like i could hardly press it and i had very little braking power at all?
Any ideas?? A ceised caliper? Leak from the booster?
#2 Posted : Monday, 11 July 2005 6:59:19 PM(UTC)
Did it take 2 feet on the pedal to pull it up?
Rock hard sounds like no booster assistance - probably a leak in the booster - usually a split diaphragm.
Did you remember to plug the vacuum hose & one-way valve back in?
#3 Posted : Monday, 11 July 2005 10:01:10 PM(UTC)
Yep it took a really hard leg to pull the thing up Everything was plugged back in.
This page was generated in 0.128 seconds.
