#1 Posted : Sunday, 17 July 2005 8:53:40 AM(UTC)
I noticed the other day when I floored it I heard for the first time what sounded like pinging, deffinatly a top end noise, then today I was towing a small trailer and the same thing happened while going up hills, all I heard was this pinging or rattling noise, when I backed off it went away??? What could it be and what to do to fix? It is pretty much bog std eng with 2 barrel stromberg. It runs on the United LRP petrol, but today I used BP 91 with an additive so it does it on both fuels? The eng was dyno tuned 5000km's ago and dosen't miss a beat.
trubluhq Offline
#2 Posted : Sunday, 17 July 2005 11:39:10 AM(UTC)
trubluhq
Firstly, stop using LRP & ULP91. Didnt know we still had it here in OZ. Use Premium ULP as a minimum. Add whatever u like after that.
Maybe check ur oil level and use a decent brand of oil too. None of this name brand 20w50 stuff. Penrite is my choice,
ozjason Offline
#3 Posted : Sunday, 17 July 2005 8:59:13 PM(UTC)
ozjason
Haven't changed anything on the engine recently? I had my 202 dyno'd, all good, then finally got around to finishing off the air con. So of course the compressor adds extra load, and it pings and rattles on load. Means another dyno, or I just put up wi
#4 Posted : Monday, 18 July 2005 6:15:29 AM(UTC)
I will try the premiun unleaded and see how it goes, as I drive it normally there is no noise, just under heavy loads.
With the oil, I only use Penrite HPR40 25W/70 in the old girl. It did wonders for the oil preasure probs these things have, gave me a
