#1 Posted : Tuesday, 19 July 2005 6:31:04 AM(UTC)
In top condition, it had over 160 on each cylinder, had to pick the exact rate, due the fact I that I don't have a screw in compression guage and it was blowing the tester out. Its still has the gearbox and starters motor on it, so turner it over to prove the compression should not be a problem. It run fine before I took it out. I can deliver.
Everything from fan to yoke.
ron
02 6684 4267
