cannon Offline
#1 Posted : Tuesday, 12 May 2009 9:30:52 PM(UTC)
cannon
We are just trying to remove the speedo cable from the back of the speedo (still in dash) and we cannot get it off. It is the type with the steel knurled nut, does not appear to be threaded as it will not unscrew. Wondering if its somehow bayoneted?? anyone shed any light on it?? starting to give us the #hits Thanks Cannon
cannon Offline
#2 Posted : Tuesday, 12 May 2009 10:13:22 PM(UTC)
cannon
False alarm pulled out speedo had some sort of crimped push on connection, cut off with grinder.
#3 Posted : Tuesday, 12 May 2009 10:56:57 PM(UTC)
about time you put a grinder to one of your cars cannon, bloody over restored boring things..HAHAHA, just continue with the grinder from the firewall till you get to the back bars, bend some moly tube up, ive got a spare fatty here, bout 540 cube, and then we will discuss the rest of the build over a few gelatis ok???
purple gts door slammer looks good to me, then we do sandman ute top alcohol car..HAHAA, drive them both to a monaro club meeting, and play spot the tags and genuine rivits..sort of hide and seek..lol
cannon Offline
#4 Posted : Wednesday, 13 May 2009 5:29:23 PM(UTC)
cannon
Well now we wreck, me being a country hick (4 header)and knowing your fetish for wrecking good one owner cars and Gelati. I have a couple of problems with that.
1/ Im on a diet so its no fat Gelati for me.
2/ The Sandman ute is needed on the farm for towing hay bales and carting poddy calves, the calves have more tags than any Monaro club.
3/ The coupe 4 I might let you have for the 540, if I dont use the all wheel drive for the local tractor pull or sand drags.
#5 Posted : Wednesday, 13 May 2009 5:55:17 PM(UTC)
I think weve strayed a bit from the original question.
Wasnt cannon trying to disconnect an HQ speedo cable, at the speedo head ?
It uses a quick connector, where you just press the plastic tag sideways & the cable will come out. You might have the wriggle the cable or at least push it inwards before you press the tag, but it is that simple. I think a grinder is a bit over the top !!
The last Holdens with a the aluminium knurled nut were the HG series, although it was continued on for LC/LJ/TA Toranas.
Dr Terry.
Edited by user Wednesday, 13 May 2009 5:59:33 PM(UTC)  | Reason: Not specified
cannon Offline
#6 Posted : Thursday, 14 May 2009 7:56:47 PM(UTC)
cannon
Thanks Terry, yep it must have been an early cable forced onto the speedo as the gearbox I removed from the HQ was a saginaw. Just gently cut across the ally nut with a fine cut off wheel until it split. Have replaced it with the standard plastic quick connector clip version you mention for the M21. Thanks Cannon
Mr Void Offline
#7 Posted : Saturday, 16 May 2009 8:13:06 PM(UTC)
Mr Void
but back to the important bit - did someone say gelati??!!! MMmmmmmm!!!
; p
___________________
Why are you reading this, you should be looking up there^^
___________________
This page was generated in 0.114 seconds.
