bathurst72 Offline
#1 Posted : Tuesday, 19 May 2009 4:23:45 AM(UTC)
bathurst72
Hi, what colour is the tail shaft in a HG GTS 308 Saginaw to 10 Bolt and what is the paint code or a colour name which is close?
Steve
#2 Posted : Tuesday, 19 May 2009 5:01:12 AM(UTC)
hi steve, heres a link to some tailshaft info http://gallery.oldholden...m/HQ_SS/Tech/Tailshafts/
Custom Offline
#3 Posted : Tuesday, 19 May 2009 7:22:36 AM(UTC)
Custom
I would wrap it in gold cellaphane, it will look grouse and make a cool wereing noise when its spinning round.
Edited by user Tuesday, 19 May 2009 7:23:48 AM(UTC)  | Reason: Not specified
bathurst72 Offline
#4 Posted : Wednesday, 20 May 2009 1:40:33 AM(UTC)
bathurst72
Hi Davequery74, thanks. The link is great but it has the same missing info I am after, it lists every other but 308 Manual cars.
Custom, I think I will pass on your idea!!!!!!!!!
Steve
#5 Posted : Wednesday, 20 May 2009 10:11:37 PM(UTC)
308 manual HT/G uses the dark green shaft.
Warren
nhawtin Offline
#6 Posted : Friday, 22 May 2009 5:02:44 AM(UTC)
nhawtin
whats this measure warren with the saginaw 308 etc
#7 Posted : Friday, 22 May 2009 8:32:17 AM(UTC)
53.71" centre to centre.
Dr Terry.
hazzard county Offline
#8 Posted : Friday, 22 May 2009 8:58:44 AM(UTC)
hazzard county
any ideas on the late hk 307 4speed 10 bolt tailshaft colour warren , dr terry or anybody else
Edited by user Friday, 22 May 2009 9:12:50 AM(UTC)  | Reason: Not specified
#9 Posted : Friday, 22 May 2009 5:44:30 PM(UTC)
From memory, it is the same tailshaft.
Dr Terry.
Edited by user Friday, 22 May 2009 5:52:20 PM(UTC)  | Reason: Not specified
#10 Posted : Friday, 22 May 2009 9:37:56 PM(UTC)
hazzard county
THANKS DOC JUST TRYING TO REMEMBER WHICH ONES WHICH I HAVE 3 LYING AROUND HERE
shifty350 Offline
#11 Posted : Monday, 25 May 2009 7:08:12 AM(UTC)
shifty350
Steve
Hello Steve,
Woodsman Green (a Holden exterior colour) would be a good one to use on the tailshaft. I have used this before with excellent results.
You should check the diameter of your tail shaft prior to buying the paint as the 2.75" diameter dark green shaft was replaced by the 3" violet shaft around the end of HG Monaro production. The last HG 308 4-speed cars had the violet shaft fitted on the assembly line and this shaft was the item carried as a replacement part from mid-71.
Hope this is of use.
#12 Posted : Monday, 25 May 2009 7:59:08 AM(UTC)
hazzard county
been told its the violet to suit late hk application can anyone confirm
shifty350 Offline
#13 Posted : Monday, 25 May 2009 8:23:43 AM(UTC)
shifty350
Hello hazzard county,
The last of the GTS 327s had this tail shaft from the factory. There is an HK Field Modification bulletin outlining this and it calls for all GTS 327s to be retro-fitted with the violet shaft in place of the dark green item. Only the 81837 model was the subject of this change at the time. Just how many cars were fitted with it is a big question even though every owner was sent a letter from Holden detailing the free change-over next time they called into their dealer.
#14 Posted : Monday, 25 May 2009 9:03:05 AM(UTC)
hazzard county
so there was a recall on the green is what your saying? i have 3 tail shafts 2 green 1 YELLOW do you have a colour code OR COLOUR NAME CLOSE TO the voilet one THANKS
shifty350 Offline
#15 Posted : Monday, 25 May 2009 9:17:45 AM(UTC)
shifty350
Yes, the green items were to be replaced with a violet one in HK81837 only. 307 powered cars were not included.
The colour we use for the violet shaft is a VHT product - Lively Lavender. Just the regular engine paint is fine, you dont need the high-temp.
Omen75 Offline
#16 Posted : Friday, 30 October 2009 5:24:44 AM(UTC)
Omen75
Hi,
I had trouble posting on the thread in the link below, something about proxy server?
http://74.125.155.132/se...cd=7&hl=en&ct=clnk&gl=au
This is what I wanted to post,
Hi, Sorry to bring up an old thread but I was searching for the correct colour for a HG GTS 350 powerglide tailshaft, I see on this thread it mentions Violet and Orange? I am doing a resto and after alot of reading I found that the original tailshaft colour is dark green and the last of the HG came out with Violet and from 71 onwards all V8s were updated or replaced with the Violet shaft?
I do not have an original shaft but have modified a 1 tonner shaft that was painted orange and wondered if this orange colour that has been talked about was basically the 1 tonner tailshaft/uni diameter?
Have used a 1 tonner yoke on diff and just about to paint the new modded 1 tonner shaft for my HG, but since reading this old post and seeing "Orange" just made me wonder.
Omen75 Offline
#17 Posted : Friday, 30 October 2009 5:29:33 AM(UTC)
Omen75
Hi,
Sorry link didnt seem to work try this
http://www.fastlane.com....OPIC_ID=17562&FORUM_ID=2
chrome yella Offline
#18 Posted : Saturday, 31 October 2009 9:22:06 PM(UTC)
chrome yella
hi fellas,
i am hoping that you might be able to tell me the correct color for my L34 tailshaft. and possibly an off the shelf alternative. cheers Gary
Mnbvcxz123 Offline
#19 Posted : Monday, 9 November 2009 5:17:59 AM(UTC)
Mnbvcxz123
Im new to this site but why would anyone paint the tailshaft any colour that black, you only see it when working on the car.
#20 Posted : Monday, 9 November 2009 6:37:03 AM(UTC)
concours cars mate, things like this can make the difference of a trophy or 5th place
personally id just paint it black, but i dont care about 100% original on my cars and i dont show my cars either, just drive and enjoy them
