#1 Posted : Wednesday, 27 July 2005 5:29:24 AM(UTC)
Looking at doing rack and pinion conversion to my Hk and brake upgrades with 17 inch wheels, i am after any help on getting it to handle, i realize it wont be comparable to todays cars but any help with spring, shockie, sway bar, wheel alignment specs would be greatly appreciated. does anyone make variable rate spring for HK. Yhanks
#2 Posted : Wednesday, 27 July 2005 5:51:28 AM(UTC)
you have the right idea there by upgrading the steering/suspension (wheel alignment should stay the same for the street), but going by your other thread fitting a big block is definately a step backwards for handling.
peter_flane Offline
#3 Posted : Wednesday, 27 July 2005 8:44:12 AM(UTC)
peter_flane
www.rodsracks.com.au
for rack and pinion for HK
