basketcasebear Offline
#1 Posted : Sunday, 31 May 2009 11:04:44 PM(UTC)
basketcasebear
jest wonderin,
as i have already written about me carby, prob,
no adjustment airfuel screws?
jest wonderin, if when i put it back on last time, the gasket not being new, has a slight leak?
could this cause the above problemo?
just a thought,
thankee already
bcb
it was but yesterday, i thought myself a fragment, quivering without rythum in the sphere of life.
now i know i am the sphere, and all of life quivers in rythmic fragments, within me!
kg.
DOH!!!
bosko Offline
#2 Posted : Sunday, 31 May 2009 11:24:38 PM(UTC)
bosko
spray some aerostart around the base of the carb and see if idle speed picks up. or crc if you dont have aerofart
#3 Posted : Monday, 1 June 2009 1:06:02 AM(UTC)
basketcasebear
hey thanks bosko,
will try that,,
but will a slight leak in gaskett cause above problemo?
or am i barking up wrong tree?
bcb
kg.
DOH!!!
bosko Offline
#4 Posted : Monday, 1 June 2009 1:29:23 AM(UTC)
bosko
yeah it can do. if your idle mix screws arent working it means you are running on the primary circuit rather than the idle circuit. this can be caused by low vacuum ie leaks
so make sure theres no leaks
#5 Posted : Monday, 1 June 2009 3:42:26 AM(UTC)
basketcasebear
BRILLIANT brilliant,, sir bosko!!!
i knight thee!!
this is probably what it is? i will get a new bottom gaskett, and throw her in,,
bet ya ..
will let yall know what happens.
regards
bcb
kg.
DOH!!!
