Hi Everyone I have a 94 Vr Acclaim Really Nice Looking car Just wondering what i can do To get a little bit more performance out of it. The Exhaust Is standard And at idle you can barely hear it anyway any help would be greatly appreciated Thanks
Buy the Supercharged VS V6 Cold air induction - it has a scoop above the radiator. The cost of the snorkel & adapter tube (into the box) is around $60, and you cut your own airbox, or you can buy an airbox already cut for more $$. I have done a page on |
I put a K&N filter straight on to the throttle body of mine, ditched the air tubing from air box. There was a small black box (about 2" long) beside throttle body which fouled it, which I swung through 90 degrees to clear filter, and all was good. It wa |
__________________________________________ Keep the shiny side up, and the greasy side down. |
get the holden CAI($60), new filter (Finer filter washable is only $60), cat back exhaust in 2.5 inch($400), with no rear resonator just straight pipe, after that fit yourself a shift improver kit like the B&M ones ($70) and if you still have a spare $150
