fitzsi Offline
#1 Posted : Tuesday, 9 June 2009 7:11:45 AM(UTC)
fitzsi
Just picked up a second hand 202 holden engine ( blue ) out of a VH Commadore supposedly and checked the the piston after checking the amount of ridge on the bore.
The top of the pistons have 1.50 stamped on them does anyone know what that means.I thought that would mean 50 thou oversize but I would have thought the norm was 60 thou oversized.Oh there isnt much of a ridge on the top of the bore at all
#2 Posted : Tuesday, 9 June 2009 3:59:31 PM(UTC)
The norm is not 60thou, its what ever the block requires I had a 253 that was 30thou over and a 202 with 40 thou over.
#3 Posted : Tuesday, 9 June 2009 4:02:28 PM(UTC)
1.5mm is very close to 0.060"?
Mr Void Offline
#4 Posted : Tuesday, 9 June 2009 7:39:15 PM(UTC)
Mr Void
$1.50 each? : ) nah, I have no idea...
___________________
Why are you reading this, you should be looking up there^^
___________________
gts308 Offline
#5 Posted : Tuesday, 9 June 2009 9:17:39 PM(UTC)
gts308
HK1837 is right 1.50mm is 59.0551181103 thou.
Thank god they still talk thou when it comes to cam lift..lol
"We are but a grain of sand on the beach of life"
