#1 Posted : Monday, 8 August 2005 5:32:59 AM(UTC)
hi, i have a 186 red motor and was wondering how to set up the roller rockers for it. they are the floating type with posilocks. wondering if there is a torque setting to do them up to or what. i presume they are always touching the valve unlike tappets. is it a fairly simple job? any help would be appreciated, thanks.
#2 Posted : Monday, 8 August 2005 8:18:39 AM(UTC)
I run roller rockers on my holden six easiest way is to adjust them the same as factory adjustables at tdc for each piston adjust them til there is no play in the push rod then 1/4 to 1/2 aturn further if you would like more info any workshop manual for 1
