#1 Posted : Tuesday, 9 August 2005 3:01:16 AM(UTC)
have leak in cooling system does anyone no the best chemical sealer
Dylan Offline
#2 Posted : Tuesday, 9 August 2005 4:11:57 AM(UTC)
Dylan
there all just band aid solutions, just fix it properly.
#3 Posted : Tuesday, 9 August 2005 4:14:03 AM(UTC)
Go to Supercheap and buy some Chemiweld its alittle white bottle
bluHJ Offline
#4 Posted : Tuesday, 16 August 2005 9:36:12 PM(UTC)
bluHJ
Depending on how bad the leak is, I use Silverseal. Available through Bursons. Cheap and easy to use. Fixed a fairly severe leak in the radiator of a friend's VN. No need to clean the system out first like you do with chemiweld. As Dylan said, i
Guest (5)
