peterwmh Offline
#1 Posted : Friday, 12 August 2005 9:58:27 PM(UTC)
peterwmh
Just looking for a couple of new donuts for my HZ. My Kingy has 185/75-14 tyres on the factory 6 inch steel rims. I have the opportunity to purchase two 215/65-14 tyres and have some 14x7 inch mags at home looking for tyres. If I were to fit these tyres to the mags would I keep the overall diameter fairly close to what it is now?
Peter
Never late with a 308!!
#2 Posted : Friday, 12 August 2005 11:12:46 PM(UTC)
Nominal OD of the 215/65 is 635.1mm
Nominal OD of the 185/75 is 633.1mm
That 2mm difference is only 0.3% difference.
Considering the difference in OD with the depth of the tread on a new & old tyre varies by some 16mm, the 2mm difference is 2/10ths
peterwmh Offline
#3 Posted : Friday, 12 August 2005 11:53:59 PM(UTC)
peterwmh
Thanks 'nut, a wealth of info as always!!
Peter
#4 Posted : Saturday, 13 August 2005 9:35:13 AM(UTC)
Hi Peter,
Also check this out: http://www.oldholden.com/possible/index.php/Maths
It will help you to work out all those tricky Automotive maths things...
Cheers...Dave
This page was generated in 0.307 seconds.
