#1 Posted : Monday, 27 December 2004 8:56:48 AM(UTC)
Will the power booster for disc brakes from an XB work with an XW/Y or are they different? Thanks in advance
#2 Posted : Wednesday, 29 December 2004 12:01:42 PM(UTC)
Yes, and yes they are slightly different but the XB one will bolt right on and work better. A good tip is that you can pull the Power brake booster, alloy calipers and 4 wheel disks off an XF falcon and bolt the right on. The cast iron calipers on an XY a
#3 Posted : Saturday, 1 January 2005 3:47:18 AM(UTC)
Thanks your tip - really does sound good (and cheap!). Do the XE rear disks simply bolt on to the XY diff housing? What happens with the handbrake cable? Similiarly do the front ones use XY or XE stub axles and is there an effect on steering geometry. I t
