#1 Posted : Sunday, 14 August 2005 7:49:37 AM(UTC)
I want to change the standard servo piston with a high performance
dual o-ring servo pistor in my powerglide..
I have read I need to remove the valve body b ut can i do this without.
I understand there is a band strut that may fall out if i try to remove the servo poston.. can anyone tell if i can cheat and do this without the need of removing the valve body.. ( trans is in the car )
#2 Posted : Tuesday, 16 August 2005 2:56:52 AM(UTC)
i dont think so.
the valve body usually comes out to change the servo.
i never really tried to do it with it in.
DO NOT WRITE BELOW THIS LINE
#3 Posted : Wednesday, 17 August 2005 9:34:56 AM(UTC)
