#1 Posted : Monday, 15 August 2005 8:57:54 AM(UTC)
does anybody know, is there a difference between a c4 box from a car to that of a c4 from an f 100? i wish to use a c4 to replace the single rail as id like to have a go at strip racing.the cars a xb coupe(fresh) 351 clevo at just under 280rw hp on the dyno, what size convertor would i use? diffs 3.55 the car is a week end driver only as i have a daily driver. (dads son, Andy thanks.)
XB351 Offline
#2 Posted : Monday, 15 August 2005 8:46:49 PM(UTC)
XB351
C4's the same. What are the specifications on the camshaft? 3.5's a good ratio. Depending on the camshaft specs you may need 2500/3000rpm?
This page was generated in 0.110 seconds.
