HQforme Offline
#1 Posted : Wednesday, 24 June 2009 5:41:48 AM(UTC)
HQforme
Id played around with gaps and heat ranges recently. Seems most info points to a 1.5mm gap with HEI ignition, which i have. But with these slightly hotter Bosch plugs the tips seem a fair way away (and back) from the electrode, like they're not really able to accomodate such a gap?
What plug would you put in a red 202, 10and a bit/1 compression, HEI ignition, ported head, bigger valves, twin strombergs and my cam:
IN. 30/70 280 adv, 214@50thou, 112 lobe centre, .440 lift
EX. 79/31 290adv, 224@50thou .465 lift.
Can't remember total timing to be honest. Set by a shop. Runs nothing but Vpower. Seems everyone swears by something different. Haha.
Edited by user Wednesday, 24 June 2009 5:43:03 AM(UTC)  | Reason: Not specified
"Silly modern cars"
petaus Offline
#2 Posted : Wednesday, 24 June 2009 5:51:43 AM(UTC)
petaus
1.5 would be close,
vintageholden Offline
#3 Posted : Wednesday, 24 June 2009 7:59:35 AM(UTC)
vintageholden
NGK are good
gts308 Offline
#4 Posted : Wednesday, 24 June 2009 9:56:59 AM(UTC)
gts308
1.5mm is about right with HEI, any closer and the electrode burns due to the higher output of the HEI.
"We are but a grain of sand on the beach of life"
#5 Posted : Thursday, 25 June 2009 3:27:01 AM(UTC)
if you have a HEI then go for some brisk plugs, they are the beez neez of spark plugs
#6 Posted : Thursday, 25 June 2009 3:31:56 AM(UTC)
they arnt cheap, but i know alot of people using them and they all swear by them, i am fitting a HEI to my HQ on the weekend and i will be buying a set after it is fitted, ebay is the only place i know where to get them from, just email the seller and he will recomend the best plugs for your car, link here
http://cgi.ebay.com.au/E...3A1%7C293%3A1%7C294%3A50
HQforme Offline
#7 Posted : Thursday, 25 June 2009 6:14:56 AM(UTC)
HQforme
Cheers guys, those are tempting :)
"Silly modern cars"
