RussVRute Offline
#1 Posted : Friday, 19 August 2005 6:44:50 AM(UTC)
RussVRute
G'day All,
I have been told by a usually reliable source that some Jaguar wheels have identical stud patterns to the HQ-HZ, and work very well, but he wasnt sure what year or model wheels to look for, can anyone shed some light on this, as I have seen some nice wheels on a few Jags, and it might be worth checking out.Cheers. Russ
#2 Posted : Friday, 19 August 2005 7:13:52 PM(UTC)
As far as I know all series I, II and III XJ6 and XJ12 plus the V12 coupe Jaguars (XJS I think they are called), as well as the equivalent Daimler Sovereigns are 4 3/4" PCD. Other models probably are too.
#3 Posted : Saturday, 20 August 2005 4:07:38 AM(UTC)
Hi Russ,
Byron has the Jag models pretty well covered AFAIK.
Just check the offset of the Jag rims and make sure they are the same or close to the Holden offset. Otherwise you could end up too far over-track or, worse, under-track.
Cheers...Dav
