#1 Posted : Friday, 26 August 2005 11:59:23 PM(UTC)
I have a top end set up to convert any SBC (pre LS1) to EFI. The following parts will all bolt straight on. All you would need to do is provide fuel and computer (Wolf 3D's are going for around $800 in quokka). All the gear is brand new and the prices below give an indication of what I paid.
1 x MSD Pro Billet Alloy Throttle body - Brand New - With Throttle Position Sensor and IAC - New price $900+
1 x Edelbrock Victor Jnr Manifold - Brand New - Mildly ported on ports and ported on intake side for better flow. New price $450
1 x Custon Alloy Fuel rails to suit manifold and throttle body. Each rail holds 4 injectors press fit. Cost $200.
8 x Brand New 42lb/h (support 650hp) injectors. New price $900+
1 x Coolant temp sensor.
1 x Air temp Sensor.
Machining of manifold to hold injectors and for sensors/vacuum - cost me $200.
Fittings (brass and stainless) all new for fuel lines etc - $100.
Total cost to me was over $2800
All gear is still in brand new condition. I still even have some of the boxes. It has been installed and tested for fuel pressure, but never started. Held a steady 45psi fuel pressure (as required for EFI).
I need to sell this ASAP so am asking $2300 neg. Im selling as I have purchased an ex HRT supercar crossram manifold.
This is an easy way for anyone to convert a SBC to EFI. All the HARD work has been done (fiddling about to get everything to fit, leaks etc). You can simply bolt this on, sort out your fuel system and hook up your ECU).
email me at stuartpassmore AT hotmail.com
#2 Posted : Thursday, 8 September 2005 10:12:36 PM(UTC)
TTT - Price drop - Must sell.
$2050
