Fastlane
Holden Forums
Holden General Discussion
350 chev + 350 trans + HQ = head ache
hi lads and perhaps even lasses, first time poster here and proud owner of a couple of resto job HQ Premiers.
ill tell you more about that later but for now...
i am having a major issue with the fitment of the 350 chev and 350 turbo trans into the HQ. the cross member doesnt sit right with the rear mount on the trans and the trans itself sits right up the top of the tunnel... the car previously had the stock 253 from factory.
i will gladly post some pictures up if there is anyone out there that could help me.
cheers simmo
Simmo
You need a Holden TH350 crossmember. Look to late HZ Statesman or pre mid 1982 WB Statesman. This assumes you have a TH350 with the Holden extension on the end. Make sure you are also using Chev into HQ engine mount adapters.
done
make with the pictures bitch!
awesome help HK cheers, my mate had a HZ crossmember so it was as easy as making up a plate that we could weld onto the original crossmember.
also.. how do i post pictures up on here? do i need to use another site like image shack?
Yup!
"We are but a grain of sand on the beach of life" |
the white one is the next project, made a little start friday by ripping out the old interior... the last bloke that had it, left cigarette butts under the carpet... next is the other prem with the 350 sitting in and the crossmember sitting incorrectly. will post pictures of how we solved it tomorrow :) http://img194.imageshack...img194/5622/p7240282.jpghttp://img156.imageshack...img156/9880/p7240274.jpghttp://img150.imageshack...img150/7477/p7240275.jpghttp://img136.imageshack.../img136/296/p7240276.jpghttp://img149.imageshack.../img149/567/p7240277.jpghttp://img294.imageshack...img294/9521/p7240280.jpgps sorry for those with 56k Edited by user Monday, 27 July 2009 7:09:21 AM(UTC)
| Reason: Not specified
Fastlane
Holden Forums
