RussVRute Offline
#1 Posted : Tuesday, 30 August 2005 8:56:42 PM(UTC)
RussVRute
G'day all,
My tonner has squeaky front suspension at low speeds which is especially embarrasing when driving through carparks with speed humps etc,(it might squeak at high speeds too but you cant hear it then because of the engine I guess!)I need to know what parts are most susceptible and can it be lubricated easily or is it likely to be a change the bushes job? As I posted once before it looks like the bushes are fairly new, but maybe the guy did'nt lube them when he put them in maybe? I dunno. I pulled the leaf springs out and replaced and lubed the bushes, but that is easy, the front end is a little more complex. any advice appreciated. Thanks. Russ.
#2 Posted : Wednesday, 31 August 2005 9:28:16 AM(UTC)
Hi Russ,
Are your front bushes rubber (black) or Nolathane (usually red)?
If they are Nolathane, the lubricant can wash out and has to be replaced. It is that thick black goo they give you when you buy the bushes.
If they are rubber, a quick squi
#3 Posted : Thursday, 6 October 2005 11:02:06 AM(UTC)
Sounds like you have some FORD parts in there somewhere dude
