barber Offline
#1 Posted : Monday, 3 August 2009 4:40:09 AM(UTC)
barber
what could i do to vn v6 heads to beef them up and make them heaps better and faster im boring the piston holes and putting oversized pistons in the engine any info on what to do to the heads to speed them up to the rest of the engine would be great
[SORARE]
[SORARE]
[SUPDUP]
playwme Offline
#2 Posted : Monday, 3 August 2009 5:31:20 AM(UTC)
playwme
Piston Holes.
Thats a new one.
Davesmonaro68 Offline
#3 Posted : Monday, 3 August 2009 6:23:29 AM(UTC)
Davesmonaro68
Depends on how stupid you want to go.
MONARO!!WHERE!!NICE
MONARO!!WHERE!!NICE
#4 Posted : Monday, 3 August 2009 6:30:13 AM(UTC)
Davesmonaro68
Stock series 2 engines will see 190+rwhp with a haltech computer upgrade.
Ecotechs will make 206+ rwhp with the same upgrade on standard engines .
Ask any speedway racer running street sedans in QLD thats what they get .
STOCK as a rock + Haltec or better computer bit better fuel pump & adjustable Reg and a decent Dyno Tuner .
Sorry forgot to add a speedshop cam and springs
MONARO!!WHERE!!NICE
Edited by user Monday, 3 August 2009 6:32:11 AM(UTC)  | Reason: Not specified
MONARO!!WHERE!!NICE
Rock_Lobster Offline
#5 Posted : Wednesday, 5 August 2009 10:29:58 PM(UTC)
Rock_Lobster
Take the heads to a reputable place that has a track record with V6 heads. Match the heads with a compatible cam. Modify the inlet manifold if required, or buy a C.O.M.E. modified one.
Then either buy a Haltech and get it tuned by a GOOD tuner on a dyno,
or keep the DELCO and get it tuned by a GOOD tuner using KALMAKER on a dyno.
If you are more DIY, then check out :- http://www.delcohacking.net/forums/
and tune it yourself.
Good luck.
Rock Lob
This page was generated in 0.212 seconds.
