Nicho71TPI Offline
#1 Posted : Friday, 7 August 2009 12:08:32 AM(UTC)
Nicho71TPI
Gday everybody.
I am currently building a HG ute and am trying to locate a decent and 100% workable power rack and pinion kit for a HG?
At the moment I have a V8 commodore rack and pinion fitted to the rear of my cross member via a Castlemain Rod Shop kit.
My first dilemma is half of the people I talk to say front mounting is better and the other half say rear is ok. Which one is it. Legally and morally??????????
Dilemma 2 is bump stop clearances and how they are affected.
Dilemma 3 is the angle of the sterring arm link from the rack an pinion in regards to the angle from the steering wheel rod is to steep and will most probably need two knuckles to join them. Is this legal(Considering clearance for extractors and so on)
Dilemma 4 is i want to fit Commodore stub axles so that I can fit later model Commodore brake (discs and calipers) system to the front as well. I definately want to stop
So basically does anybody know of a working, fitted and legal power rack and pinion kit on a HK,HG,HT vehicle that would bewilling to give advice, pics and inspection if located nearby?
I have spoken to Hopper Stoppers and I am not happy with the kit they offer. Spoken to Blacks Racks and they only do kits for HQs at this point in time (which is a shame they have a nice looking kit)
Any assistance in helping me get my ute on the raod will be greatly appreciated.
Nicho
Iam a fuel injected suicide machine!
bathurst72 Offline
#2 Posted : Friday, 7 August 2009 6:58:52 AM(UTC)
bathurst72
You are a member of these groups:: Registered
Hi Nicho, welcome to the site. I have sent you an email please contact me.
Steve 0427197267
#3 Posted : Friday, 7 August 2009 11:45:12 PM(UTC)
Last I heard Blacks Racks were working on a HK-HG kit. Give them a try.
Otherwise front racks are nowhere near as common as rear mounted racks but Cortinas (power racks are rare as), Rover SD1s, Subarus, Volvos, Jaguars, RX7s, some BMWs and some later grey imported Skylines had front racks so they may be a candidate
If at first you dont succeed then skydiving is not for you.
Utility8 Offline
#4 Posted : Saturday, 8 August 2009 2:02:18 AM(UTC)
Utility8
As HK-T-G have the drag link assembly at the rear of the crossmember from factory, I would suggest that the preferred position of a rack would also be at the rear. The rack of choice would need to have the same dimension from inner tie rod end to inner tie rod end as the drag link has. The tie rod dimension will then also match the originals. Keeping those dimensions as factory was, will maintain the factory toe in/toe out around corners, the "ackerman principle"
Checkout this link for a simple demonstration.
http://www.davehaughey.ca/right_turn.gif
A front rack fitted to a front crossmember that was originally designed for a rear drag link system is virtually impossible to achieve the correct geometry.
A case in point is a HR crossmember utilising a front rack. I have one (not CRS) in an EH, 23 years now, and the geometry is incorrect. It toes in around a corner rather than toeing out. Dont believe people that tell you this is not the case. It is a fact. I built the car in the mid 80s, and still believe that front rack is simply a compromise to make a V8 conversion reasonably simple. Front racks on HR crossmembers are the easier option for a V8 conversion. Sump & exhaust clearances are the stumbling blocks for a rear mount rack with V8, particularly Chev. If this can be sorted, as guys have done, the rear rack is a far better option to achieve correct geometry.
The next point to consider is the height of the rack when fitted to the crossmember. As the control arms cycle up & down through the full suspension travel, the degree of steering, ideally, should not vary throughout this cycle of travel. At any degree of steering angle that the wheels are positioned in for this test, it should comply. If the rack is not at the correct height in relation the the steering arm & lower control arm position, the up & down cycle of travel will change the degree of wheel position. This will in effect, steer the car as the suspension goes up & down.
I suppose the only other point to consider is CRS & correct geometry, should they ever be used in the same sentence?
Utility8
Edited by user Saturday, 8 August 2009 2:09:15 AM(UTC)  | Reason: Not specified
utility8
#5 Posted : Saturday, 8 August 2009 2:43:52 AM(UTC)
Very good Utility8, I couldnt have said it better myself
In the 4 decades that Ive been working on cars Ive yet to see a rack & pinion conversion that works as well as the linkage system it has replaced. The bump steer & toe-out on turns is always forgotten.
gts308 Offline
#6 Posted : Saturday, 8 August 2009 8:15:49 AM(UTC)
gts308
Pinched from another forum.
Re: Steering Rack into HT-HG
UC Torana rack works well in front of the cross member. The width is good and bump steer is minimal. I had to knotch the cross member for the pinion shaft. I had to get tie rod adapters made as well. I used HQ steering arms to try and get the Akermans angle as close to correct. If you reverse the stock arms it is way out.
Castlemaine Rodshop make a kit that uses a Commodore rack behind the cross member. I prefer the front mount because the rear mount is a long way behind the x-member and limits sump size.
I had to cut into the outrigger. I bolted a plate to strenghten it after the rack was mounted. This is my old car. It was in Extreme Magazine last year. The photo shows it pretty well.
Edited by user Saturday, 8 August 2009 8:28:11 AM(UTC)  | Reason: Not specified
"We are but a grain of sand on the beach of life"
Oily Offline
#7 Posted : Saturday, 8 August 2009 8:31:11 AM(UTC)
Oily
Remember LC LJ Toranas with their front mounted racks and how without toe out on turns the front tires were fighting each other fiercly on U turns.
Utility8 seeing that word Ackermann brought old trade college memories of drawing in the imaginary lines that I think should pass through the king pin axis (ball joints) then the outer tie rod ends these lines from both sides of the car should meet somewhere down near the diff. Impossible on HQ,s and LJs.Lucky they handled as well as they did.
Utility8 Offline
#8 Posted : Saturday, 8 August 2009 8:51:41 AM(UTC)
Utility8
I found this on a simple Google search. Probably the easiest explanation I have seen.
If this doesnt make sense, its probably not worth trying to understand steering geometry, let alone re designing it.
If you follow how it works, then consider using a front rack on a frontend designed for a rear link assembly, such as a HR unit.
The outer tie rod ends will need to be where the front tyres are. Can that be done?
No, it cant.
Images 3 & 4 are typical of the problems created by a rack mounted to the front of a HR front crossmember. (HK-T-G are in the same boat)
Image 3 is what you have with a front mount rack.
Image 4 is what you get when trying to steer.
Image 5 is what you are unable to achieve as the front tyres are in the way.
As I said in my previous post, I have a HR cross member in an EH with a front rack. 23 years of it. It is a compromise at best. The geometry is not right & really, with what I now know, should this design of steering modification be able to be legally registered?
This information below was sourced from the following link. http://www.nationaltbuck...is/ackerman/Ackerman.asp
ACKERMAN STEERING
Maybe this will help some of you guys to understand the Ackerman principle and how it affects T-Buckets. The basic theory is that the front wheels of a 2 wheel steer vehicle with the steering on the front should remain tangent to the turning circles of each individual wheel. It is theorized that the center point of these circles falls on a line that is the same as the centerline of the rear axle housing projected out into space. The center of the both arcs is at the same point on the rear axle centerline. That centerpoint slides along that line as the amount of steering input is changed. In other words, on a small amount of turn the centerpoint is way out there, in a hard turn the center is closer to the car. In the straight-ahead position the centerpoint is at infinity. Thats way, way, way out there! Its time for a little drawing to keep from confusing you with this attempt at an explanation.
As you can see, the left wheel turns on a shorter radius circle and needs to turn sharper than the right wheel to remain tangent to its turning circle. Why do these wheels need to stay tangent? That places the least amount of side loading on the tires and suspension components. In other words tire and parts wear is going to be minimized. How do we get the geometry such that this desired effect is achieved? Fortunately Mr. Ackerman came along and figured out that if he arranged the mechanical parts of the steering system so that the pivot points of the linkage (tie rod) that connected the two front wheels were closer than the pivot points for the front wheel mounting assembly (spindles with their kingpins), it would affect how the wheels reacted when turning was occurring. He apparently noticed that if he made these points such that if you drew a line from the center of the kingpin to the center of the rear axle housing and placed the tie rod ends center on that line, it would give the desired change in the angles that the two wheels turned. Old Mr. Ackerman found that he had a principle that applied universally. I bet he was pretty proud!
Time for another illustration. O.K., automobiles steered fine and everyone was happy. And along comes Joe Hot Rod and he decides that his heap needs to be nice and low. Hey, no problem. Lets move the spring back behind the axle and down nice and low. Looks great, in da weeds! Oops, small problem, no place for the tie rod to run back there. Imagine that you can see a "great idea" light bulb over Joes head. Hey thats easy, just swap the spindles side for side and put the tie rod on the front. Look, the wheels still are connected and turn when you give the steering wheel a twist. That will cure all of my problems.
Well not quite Joe. You have just wiped out Mr. Ackermans principle. Your tie rod attachment points (tie rod end or heim joint) no longer fall on that imaginary line. So what happens now? Well, either the inside wheel does what it is supposed to do, or the outside wheel behaves correctly, but not both at the same time. So now old Joe has that nice set of new high dollar tires grinding themselves up on the local asphalt every time he goes around a corner. The car also has a tendency to get a little quirky because the wheels cant make up their minds which one is going to be in charge of where they are going to point.
Is old Joe just screwed on this deal now, stuck with this problem? Nope! He just needs to get those pesky attachment points back over on Mr. Ackermans imaginary line. It works just as well on a front mounted tie rod as a rear mounted one. Remember, Mr. Ackerman found out that it was universal. It depends on what he has for front-end hardware as to what he can do to correct this situation. Early Ford spindles with the built on steering arms can be heated and bent to get back out there where they should be. Just be darn careful doing it; if you dont know what youre doing find someone who does and have them do it. The aftermarket offers some parts that can take care of this problem. Sometimes special design parts will need to be made. A lot depends on the individual situation. Brake configurations (calipers and rotors mostly) can create some interesting obstacles. If you cant get out there where Mr. Ackerman says you should be, at least get as close as you can.
Lo and behold, old Joe made the changes and guess what? His lo and in da weeds bucket is cruising along lifes highway is fine style. Tire life is improved, steering is less quirky (still needs a little work on the bumpsteer deal) and he is all smiles.
Well, old Joe is not alone on this deal, hes got lots of buddies with the same problem and they havent done a thing about it. So what happens? Well they just go cruising alongof course they stop by the tire store a little more often than Joe and leave some of their hard earned. And they have to pay a little closer attention to where their missile is headed when all of the guys are out for a cruise and find that great little road with all of the curves that just beg for a guy to open it up just a tad.a tad? Yah right!
By George Barnes
Edited by user Saturday, 8 August 2009 9:35:08 AM(UTC)  | Reason: Not specified
utility8
hg_lover Offline
#9 Posted : Saturday, 8 August 2009 10:20:56 PM(UTC)
hg_lover
Hi Nicho,
I have a HK ute I bought as a project car that has a commodore rack and pinion set up mounted behind the crossmember. Ive got VT 2 pot calipers and discs on the front too. When I got the brake mob to fit these up I know they did have to do a bit of work to make them fit.
The connection of the steering shaft to the power steering knuckle looked a bit dubious at first but all was needed for my setup was a bearing/bush in the bottom of the steering arm to keep it aligned and then just fastening the shaft to the knuckle.
The only problem Ive had so far is the sump clearance for my 350 chev but this was easily fixed by fabricating an old HQ sump to suit.
Getting the engine installed in the next few weeks fingers crossed then Ill be getting the steering rack mod plated etc.
Im up in Toowoomba so if you feel like a short drive youre more than welcome to come check it out, otherwise I can organise some pics.
gts308 Offline
#10 Posted : Sunday, 9 August 2009 12:57:18 PM(UTC)
gts308
Im afraid I dont totaly agree with Mr Ackermans theory...But then again I think the moon landing was fake!
Utility8 Offline
#11 Posted : Sunday, 9 August 2009 9:10:42 PM(UTC)
Utility8
Im confused GTS308.
Why would you try & get the Akermans angle as close to correct when I dont totaly agree with Mr Ackermans theory?
Utility8
utility8
gts308 Offline
#12 Posted : Monday, 10 August 2009 8:47:40 PM(UTC)
gts308
Originally posted by Utility8
Im confused GTS308.
Utility8
As I stated in the post I found that posted on another forum and just pasted it in...It aint my car or idea!
But getting back to the Ackerman linkage principle. Clearly this is beneficial at low speeds when your taking your car out shopping as the tendency to scrub the tyres is greatly reduced or even eliminated. However, at higher speeds and greater loadings this does not necessarily follow.
In a high speed corner, weight is transferred to the outer wheel thus a increasing the loading and therefore requiring a greater slip angle. It is, therefore, not uncommon for cars to employ a certain amount of "anti Ackerman". After all its tire slip angles that influence the actual turning radius.
Nicho71TPI Offline
#13 Posted : Wednesday, 12 August 2009 10:31:11 PM(UTC)
Nicho71TPI
Gday everybody.
Thankyou one and all who posted a reply to my topic and all replies have been of great value and help with my project. Please do not hesitate to keep replying to my my topic. I definately want to get my ute up and running and turning and stopping!
I will definately get in touch with hg_lover and go and have a look see at what he has allready accomplished with his project. Cant wait!
Also hopefully when I get a bit more tech savy I will post some pics of my ute and the shed its in (i read some posts on sheds and mine measures 14.1 mtrs L, 7.6mtrs W, 3.6 mtrs H at the gutter. 3 roller doors and a work area)
marksg62 Offline
#14 Posted : Thursday, 20 August 2009 4:53:59 AM(UTC)
marksg62
Try www.rodsracks.com.au,they are in SE QLD.
Guest (5)
This page was generated in 0.225 seconds.
