HQforme Offline
#1 Posted: : Friday, 14 August 2009 5:39:52 AM(UTC)
HQforme
Casting no: 7438296. Its a YT high comp head, i assume based on a 186. Has 3/8 studs. There are washers under the studs. Is this common practice?
I have shaft mounted roller rockers on my current head. I've been told you can pull the studs from the YT then drill and tapp for the shaft mounts? Or is it not worth it considering the motor only sees 5500 and the cam's a 30/70 with 440/460 lift int/ex?
Cheers.
"Silly modern cars"
Grue Pugg Offline
#2 Posted : Friday, 14 August 2009 6:05:08 AM(UTC)
Grue Pugg
HQforme Offline
#3 Posted : Friday, 14 August 2009 7:05:42 AM(UTC)
HQforme
Haha, holy hell. I tried every search you can think of with Holden head ID, casting numbers, etc and each time there were thousands of sites with snippets of info.
To think a simple "head 7438296" would have worked a treat. Same on Holdenpaedia. Seems its a 161 head. Cheers.
Looking at some pics, my studs have a hexagonal base. Are they screw in? Or just different to old ones that are simply a straight stud out from the casting.
Edited by user Friday, 14 August 2009 7:08:07 AM(UTC)  | Reason: Not specified
"Silly modern cars"
Grue Pugg Offline
#4 Posted : Friday, 14 August 2009 7:47:46 AM(UTC)
Grue Pugg
screwins
dca1042 Offline
#5 Posted : Monday, 17 August 2009 6:44:39 AM(UTC)
dca1042
they are in fact screw in studs and the washers were fitted because the posts are machined the extra bit to accomodate guide plates.
cheers dave
