#1 Posted : Tuesday, 6 September 2005 7:37:01 AM(UTC)
Red 06/79 Factory 351 3 speed auto Fairmont Ghia, converted to single rail. Non-original engine (it's a blue engine). Originally brown interior, changed to grey.
The good stuff;
Complianced for LPG, however no gas system is fitted.
Power windows work.
Interior is in great condition for its age, be hard to find a better one.
New clutch, clutch line, slave cylinder and clutch pedal.
new upper thermostat housing, thermostat and heater hoses.
RHF door handle a few weeks old.
Straight body, no major dents at all.
Very minor rust, bottoms of the C-pillers are fine, around the back window is fine.
Holley 600 (needs repair to front float bowl, one of the threads for the accel pump is stripped and it leaks).
Comes with mech and elec dizzy, can't vouch for the condition of the elec dizzy, haven't run it with it in. I believe the mech dizzy needs a rebuild.
Momo steering wheel.
That bad stuff;
Engine needs a rebuild (massive blowby).
Rear main leaking (why I didn't replace....duh).
Power steering leaking.
Combination switch is broken, have a spare though (way too lazy to put that in)
Speedo doesn't work.
Rust in the front of the LHS sill panel. Hole (about 4-5 inches by 1.5 inches) on the inside of the sill (can only see from underneath).
Surface rust in a few spots (above tail light, two of the doors, one of the rear wheel arches.
Paint lifted after removing rear side mouldings.
Both mirrors broken, LHS still intact though.
No radio.
Cental locking not hooked up.
No A/C.
I have an XE Ghia front (panels, bonnet, headlights, grill and bumper with lip) I can supply for a bit extra. RHS headlight lense needs replacing, otherwise perfect.
I'm after $1700 for the car, make me an offer though. XE front I'd be after $250 for, but won't sell until the car is gone.
Will also consider swap for XA/XB Coupe, rolling shell or with running gear. It's a long shot, but hey.
Edited by user Tuesday, 6 September 2005 8:18:28 AM(UTC)  | Reason: Not specified
This page was generated in 0.464 seconds.
