2 Pages<12
#21 Posted : Friday, 21 August 2009 12:26:21 AM(UTC)
There is this but I could not tell you whether its for a red or a blue 6 and neither can the seller if you read the answer to his question.
http://cgi.ebay.com.au/T...en_W0QQitemZ180398083387
If at first you dont succeed then skydiving is not for you.
Mr Void Offline
#22 Posted : Friday, 21 August 2009 2:32:24 AM(UTC)
Mr Void
haha, that answer is priceless! Im pretty sure Strata 3 were the first of the 12 port manifolds. I might ask for a photo from the other side..
___________________
Why are you reading this, you should be looking up there^^
___________________
Mr Void Offline
#23 Posted : Tuesday, 25 August 2009 3:32:14 AM(UTC)
Mr Void
Well, I asked the seller for another photo and this was his reply (he didnt post my question);
"Hi, the manifold is for a Red motor (so 8 ports) but can be pre drilled to fit a blue motor (12 ports) Cheers"
___________________
___________________
peter_flane Offline
#24 Posted : Tuesday, 25 August 2009 7:46:11 AM(UTC)
peter_flane
Isnt a Red motor considered 9 port?
I have seen a few conversions between 9 and 12 port manifolds over the years. Not ideal, it is like using 13mm spanner for 1/2 inch or vice versa.
http://www.ehlimo.com.au/
Mr Void Offline
#25 Posted : Tuesday, 25 August 2009 6:51:12 PM(UTC)
Mr Void
yep.
___________________
___________________
Guest (5)
2 Pages<12
