Fastlane
Holden Forums
Buy, Swap & Sell - Holden
HK HT HG HOLDEN MONARO PARCEL SHELF, REPLACEMENT P
TO SUIT HK , HT, HG MONARO COUPE, FULL REPLACEMENT PARCEL SHELF, AS PER ORIGINAL PRESSINGS...( TO REPLACE RUSTED / DAMAGED / BUTCHERED OUT UNITS
AS PER FACTORY ORIGINAL, REPLACEMENT PARCEL SHELF
FEEL FREE TO CALL US ( 03 54 72 1332) FOR ANY QUESTIONS...
FABRICATED FROM 1.00mm HI QUALITY CA3 BODY STEEL.
SEE OUR OTHER LISTINGS FOR OUR EXTENSIVE LIST OF HAOLDEN PARTS...WE ARE DEVELOPING NEW ITEMS ALL THE TIME...SO KEEP IN TOUCH FOR NEW ITEMS..
WADDINGTONS STREET RODS
73 BLAKELEY ROAD
CASTLEMAINE 3450
CONTACT US FOR FREIGHT RATES AROUND AUSTRALIA
I am giving it an "A"
Please put some stuff on YouTube so we can see you guys at work
i seen there stuff at the last ballarat swap meet, all panels were perfect, i have heard many good things about waddingtons and none bad
quality, price and market demand is right, so hows the sales going? moving stuff alright?
Thanks: 1 times Was thanked: 607 time(s) in 574 post(s)
Guys, I tell you what would be a good HK-HG coupe panel to do: the 2 x rear inner panels that run vertically from the lip where the boot closes, down towards the rails. The inner wheel arches, boot floor, tail-light mount, parcel shelf etc are the same as sedan but these two are unique to coupe. Often they are damaged when a car has had a quarter replaced 30 years ago, and the inner panel never repaired properly. Ive collected a spare or two over the years off cars that have been cut up for quarters, but that practice just doesnt happen anymore. The LH one has an extra hole on 1837M coupes, but it is a punched, rough hole anyway and could easily be done post manufacture.
The other coupe panels getting hard to find (but not sure on the market for them) are windscreen pillars (especially the July 68 examples), early cowl panels (without the holes for the BODY tag) and beaver panels. Cowls and beavers are common across most body shapes but its very hard to find a body nowadays with good enough examples to cut off.
you got a web site?, so we can keep track of whats avaliable or whats comming? thanks
HOLDEN The Great Way to Move |
What would my original HK GTS rust free parcel shelf be worth? I cut it out as it had rust around the window sill. Would be perfect for a speaker hold patch up. Was going to chuck it.
Matt |
Matt
Have to be worth s*** loads cause its from a GTS!
BAAAAAAAAAHAHAHAHAHAHAHAHAHHAHAHAHAHAH
Same as a rust free Kingswood one I imagine.
Fastlane
Holden Forums
