adam PERTH Offline
#1 Posted : Tuesday, 25 August 2009 5:05:27 AM(UTC)
adam PERTH
Just have a question about coil packs.
I have just swapped a few coil packs around on a couple of VPs.
can i use the individual pack (i.e. one out of the three)
in a different spot?
1+4
2+5
3+6
can i use one which has 1+4 written on it in the spot where the 3+6 goes? Are they the same apart from the numbers written on the top of them?
adam
WANTED:
-2 14 x 9.25 CSA style Centrelines.
-2 x 15 x 8 Dragway centrelines
80569K Offline
#2 Posted : Tuesday, 25 August 2009 6:45:20 AM(UTC)
80569K
Well, the aftermarket coil packs are not marked so I reckon you might be safe to stick em wherever you desire.
Casper Offline
#3 Posted : Tuesday, 25 August 2009 10:43:58 AM(UTC)
Casper
You can cut up the one peice 6 coil pack and use individual coils too.
adam PERTH Offline
#4 Posted : Tuesday, 25 August 2009 10:32:08 PM(UTC)
adam PERTH
Cheers, thanks.
i assume the coil pack base plate network determines the spark, not the coil pack itself.
thanks again. i will give it a go.
WANTED:
davidb9 Offline
#5 Posted : Wednesday, 26 August 2009 3:39:58 AM(UTC)
davidb9
Hi guys 80569K is right should not make any differance where they are placed.
This page was generated in 0.329 seconds.
