FE350 Offline
#1 Posted : Sunday, 6 September 2009 1:33:06 AM(UTC)
FE350
Hello all, i would like to know how to get a certificate of authenticity for my hj monaro also would someone be able to help me decipher the id tags i know the car came from factory jade green and thats it the comp plates details are
Model HJ8WQ69
body 136051-A
trim 1899-60 V
paint 567-15945
engine L31
trans M41
diff GU4
chassis 8Q69TEL295286J
built date 02/75
Any help would be muchly appreciated!
hqgts Offline
#2 Posted : Sunday, 6 September 2009 1:51:17 AM(UTC)
hqgts
for a COA you need to call the Holden Customer service centre by phone or email [email protected]
Model HJ8WQ69 = monaro GTS sedan
body 136051-A = 136,051st adelaide built HJ
trim 1899-60 V = chamois/covert vinyl trim
paint 567-15945 = jade green metallic
engine L31 = 308v8
trans M41 = turbo 400 auto
diff GU4 = ratio 3.36:1
hope that helps
Edited by user Sunday, 6 September 2009 1:52:44 AM(UTC)  | Reason: Not specified
FE350 Offline
#3 Posted : Sunday, 6 September 2009 2:54:49 AM(UTC)
FE350
Thankyou hqgts thats exactly what i was after if your at my local pub this arvo ill buy ya a beer or two! cheers..
anonymous Offline
#4 Posted : Sunday, 6 September 2009 4:02:54 AM(UTC)
anonymous
A GV4 diff code is 3.36:1
GU4 is a 3.08:1 diff ratio
#5 Posted : Sunday, 6 September 2009 4:32:19 AM(UTC)
"body 136051-A = 136,051st adelaide built HJ""
These body numbers (which form the Tag number when prefixed with an L, J or H) are assigned sequentially, and dont reset at the start of a new model. The chassis numbers do though. (like the BHJ012345A ones).
Also, when the body numbers do reset, they dont go back to 0.
All the resets commence from 101000 or 100000, not 000000 (the jury is still out on the first 1000 being reserved for pre-production, like engine numbers, as theres no need to reserve them for body numbers).
In the VH era - July 83, they got up to 599999A and reset to 100000A.
In the VS (first week of December 1996), they went from 999999A to 200000A (dunno why they didnt go to 100000A).
In the VY (April 03), they went from 999999A to 100000A.
The other problem you have, is you cant count them as accurate measurements of production, due to multiple lines at the same plant all using the same body number sequences. Melbourne is a good example of multiple lines. Commodores built there had J tag numbers (ie J987654) but Camiras were also built there, alongside commodores. Camiras used the sequential body numbers a well - shared with commdores.
So J900001 might have been a VK SS, while J900002 could well have been a Camira SL/E.
You may find out of 100,000 body numbers, 85,000 were commodores, and 15,000 were Camiras.
Ill give you some examples of why you need to use the chassis numbers, not the body numbers for counting purposes.
I will use VLs, as I have over 3000 VL body number & chassis numbers recorded (all by hand, off cars at shows, wreckers & ebay), which is the most for any model out of all my commodore records:
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
Earliest Melbourne VL I have recorded (1/86):
Body: 984607M
Chassis: AVL000392M
(Melbourne body numbers went from 999999M to 100000M in June 86).
Latest Melbourne VL I have recorded (10/88):
Body: 174423M
Chassis: AVL059633m
Melbourne body number spread: 89,815 tag numbers
Melbourne Chassis number spread: 59,633 VLs.
Difference: 30,000 odd.
Earliest Adelaide VL I have recorded (12/85):
Body: 199864
Chassis: AVL000122A
Latest Adelaide VL I have recorded (7/88):
Body: 294460A
Chassis: AVL089929A
Adelaide body number spread: 94,596 tag numbers
Adelaide Chassis number spread: 89,929 VLs.
Difference: a bit under 5000.
So you can see in Melbourne, some 30,000 other cars were made during the VL period, drawing from the same pool of body numbers as VLs, but they werent VLs.
Adelaide wasnt as bad - only 5000 odd body numbers werent VLs during that period.
According to the Holden Heritage (the little booklet that comes out early every year) there were 151,801 VLs built. Adding up the highest chassis numbers I have recorded: AVL089929A and AVL059633m is 89,929 + 59,633 = 149,562, which is pretty close, and backs up the accuracy of my collected data.
LHQ-253 Offline
#6 Posted : Sunday, 6 September 2009 4:52:45 AM(UTC)
LHQ-253
Hi FE350,
The letter you get from Holden should give the following information;
Date of completion: 11/3/75
Engine Number: QT594960
Transmission Serial #:02352
Selling date: 4/75
Selling Dealer: 822- Kevin James Motors P/L, Cannington
Options: Power Steering & Air Conditioning
It is interesting that this car was built much later than others with similar VINs, which were all built around 12/74.
Hopefully this information is helpful and the same as what Holden provides!
Regards, Andy.
#7 Posted : Sunday, 6 September 2009 5:12:19 AM(UTC)
Actually Mick, at that time at the Adelaide plant the Body number was not the same as the PSN component of the VIN. All other plants had changed at this time though.
So this was the 136051 Holden/Statesman built since HQ at Adelaide.
Adelaide switched over to the "new system" during HX.
Warren
papaya hx Offline
#8 Posted : Monday, 7 September 2009 5:49:54 AM(UTC)
papaya hx
LHQ-253 How did you get all that info as my letter from holden gave me no eng no. or dealer or options. If you can search my car I would love to give you my cars numbers just let me know which no.s you need
Many thanks Ron
LHQ-253 Offline
#9 Posted : Monday, 7 September 2009 5:55:52 AM(UTC)
LHQ-253
Hi Ron,
either post up the VIN or email it to me [email protected] and Ill se what I can find.
Quite often the records dont include the engine number, and many of the 3 digit dealer codes are unknown.
Regards, Andy.
papaya hx Offline
#10 Posted : Monday, 7 September 2009 6:01:05 AM(UTC)
papaya hx
Thanks Andy Vin no. is 8q69tgh411384x
LHQ-253 Offline
#11 Posted : Monday, 7 September 2009 6:24:39 AM(UTC)
LHQ-253
Hi Ron,
The records give the engine number QT828777, and it had a M21 box and 3.36 diff. No air/con or p/steer fitted. Production date is given as 3/2/77, but not sold until 12/77. Selling dealer (729) is unknown. (by me).
It is strange that GMH couldnt give you the engine number as Im almost certain they operate from the same set of records that I do.
Hope this helps, regards Andy.
papaya hx Offline
#12 Posted : Monday, 7 September 2009 6:58:29 AM(UTC)
papaya hx
Thanks Andy My letter from Holden says build date 19.1.77 & paint code 1916 (17777) papaya which was the only colour on the chart you could not get a GTS/4 in. Around 8 yrs ago Holden told me it was a special order colour but could not work out why it not sold until the 12/77 which was 11 months later. I believe the car may have been an internal car as I have a photo of what I believe to be my car on the paved turntable at Holden (the photo is also on the home page of the monaro club of VIC) I would love to know if the likes of Borret or Bagshaw remembered the car but I guess we will never know Thanks again for your help & sorry for stealing this thread Ron
LHQ-253 Offline
#13 Posted : Monday, 7 September 2009 7:23:32 AM(UTC)
LHQ-253
Hi Ron,
Strange that the production dates differ. It was possible to get cars painted a non-standard colour. Tricky, but possible. Your car wasnt an internal car, as the internal dealer codes are known. John Bagshaw is alive and well and may well remember more.
Andy.
papaya hx Offline
#14 Posted : Monday, 7 September 2009 7:45:07 AM(UTC)
papaya hx
If it was a special order colour why did it sit for 11 months unsold . Can anyone explain the photo on the turntable. Can anyone pass this question on John Bagshaw or know how to contact him Thanks Ron
LHQ-253 Offline
#15 Posted : Monday, 7 September 2009 8:04:30 AM(UTC)
LHQ-253
Perhaps Papaya was a hard colour to sell back then. The dealer code (729) possibly belonged to a small rural dealer in Far North Queensland, therefore it is quite possible that it sat in the showroom(?) for some months.
Another explanation could be that the car IS the only one, AND the one on the turntable, AND was used internally for some months, before being requested by dealer 729.
I really dont know. But someone might. Hang in there Ron.
papaya hx Offline
#16 Posted : Monday, 7 September 2009 8:09:02 AM(UTC)
papaya hx
Thanks Andy
shifty350 Offline
#17 Posted : Tuesday, 8 September 2009 1:23:12 AM(UTC)
shifty350
All,
The number of bodies built in Adelaide at that time in history also included Bedford - not just vehicles from the HJ series programme. The body number in question - 136051 - up to that point would have included the vehicles Warren mentions as well as LJ Toranas and Bedford commercials. It was a cumulative total of all vehicle bodies built at this location.
Hope this is of use.
shifty350 Offline
#18 Posted : Tuesday, 8 September 2009 1:46:52 AM(UTC)
shifty350
papaya hx,
This may be of use to you. The date quoted by Holden in relation to the build date of your car may be the projected sales date and not the build completion date. Or it could be the date the car started the production process. The chances that your car (H411384) was the car on the turntable you mention is remote at best given the assembly plant that built the car. The car sounds like a CTV (colour-trim variation) order to me given the information provided by Andy. The Zone that the vehicle was ordered through will be of use here. Either way, a Papaya HX GTS sure sounds like a very nice car.
Hope this is of use,
Ben Stewart.
papaya hx Offline
#19 Posted : Tuesday, 8 September 2009 4:09:38 AM(UTC)
papaya hx
were torana,s & sandmans built in melbourne
papaya hx Offline
#20 Posted : Tuesday, 8 September 2009 4:11:58 AM(UTC)
papaya hx
Sorry I forgot to say 1977 torana & hx sandman,s
Guest (20)
This page was generated in 0.088 seconds.
