westozmonaro Offline
#1 Posted : Tuesday, 8 September 2009 11:05:54 AM(UTC)
westozmonaro
have read a few comments about the rochester quadajet being better on 327,s than say holley carbs but then some nicelooking polished off the shelf holley set ups also avaialble
so for a 327 / fuellie heads and a little bit warm in general with turbo 350 auto in a hk , some thoughts from guys who are experienced with 327,s and there carby / combo choice
am after some good street drivability / cruising
#2 Posted : Tuesday, 8 September 2009 4:16:47 PM(UTC)
I ran a Quaddie off a WB on basically the same combo (but in an MQ Patrol with TH400). It was really good. It was a 307 + 0.060 (about 317ci) Only problem was it was a cast iron original HK manifold so it needed a carb spacer to seal the original EGR crossover under the carb, but with an alloy manifold tht problem wouldnt exist.
adam PERTH Offline
#3 Posted : Wednesday, 9 September 2009 5:36:27 PM(UTC)
adam PERTH
yes all the early manifolds MUST require the big thick cardboard gasket if you dont have a spacer when you run the quaddie.
go for the Quaddie,
or Edelbrock carb if you after street looks, its basically the same..
WANTED:
-2 14 x 9.25 CSA style Centrelines.
-2 x 15 x 8 Dragway centrelines
Utility8 Offline
#4 Posted : Wednesday, 9 September 2009 7:05:30 PM(UTC)
Utility8
I still have an early Quadrajet sitting on top of a reasonable 327 fuellie headed small block after 23 years. It is in an EH & only recently I replaced the TH350 with a TH700 as it broke. Diff gears are 3.5:1.
From my experience with this combo, I reckon that it is a terrific carby for that drivability/performance/economy balance that we all want. I am not sure about comparing them to any after market carby. If you do travel the path of a Quadrajet, either study them well & understand them, or find someone that has a great depth of knowledge/experience with them & pay them. They are a fiddly carby compared to some, but once setup to suit your application, they are quite good. Economy on a trip was around 15mpg. Now with the TH700, around 21mpg due to overdriven fourth gear.
Remember, a good looking, polished carby, only looks good when you are stopped with the bonnet up. My view is that practicality comes before beauty.
Utility8
Edited by user Wednesday, 9 September 2009 7:06:47 PM(UTC)  | Reason: Not specified
utility8
80569K Offline
#5 Posted : Thursday, 10 September 2009 1:48:43 AM(UTC)
80569K
My HK 307 has a cast #3866922 inlet manifold on it along with a 600 Holley, question is if I switch over to a HK era quaddy will I need the spacer?
#6 Posted : Thursday, 10 September 2009 4:38:57 AM(UTC)
#3866922 inlet manifold is for a Early-Mid 60s 4GC Carby and is no good for Quadrajet . You need a 3919803 or from a HK 327 or 68 Impala , that way you can run a proper 7028212 Auto Carby and use the original baffle/shim and manifold choke system . People carry on about them , but if all is in good condition they are great . I have been selling all this stuff for years and have many happy people . People run into trouble with that "quaddies are all the same mentality) but if all is matched right you will have trouble free motoring . cheers James
www.monaromuscleparts.com
Edited by user Saturday, 12 September 2009 5:58:16 AM(UTC)  | Reason: Not specified
80569K Offline
#7 Posted : Thursday, 10 September 2009 6:47:03 AM(UTC)
80569K
Sounds like a new manifold & carby comin up then.
Edited by user Thursday, 10 September 2009 5:36:44 PM(UTC)  | Reason: Not specified
#8 Posted : Friday, 11 September 2009 8:38:10 AM(UTC)
westozmonaro
so what about if you want to run an aftermarket manifold with the quadrajet ,
adam PERTH Offline
#9 Posted : Friday, 11 September 2009 8:46:11 AM(UTC)
adam PERTH
no problem with aftermarket manifolds.
a good inlet to run with a stg 3 cam (2500rpm - 5500rpm) is the "Edelbrock Performer RPM - QJET"
the next one up from the edelbrock performer, but designed specifically for the Rochester Q-Jet.
Its normally a special order at most speed shops.
most other Stg 3 inlet manifolds are square bore, which means an adapter to go to spead bore, and a hole cut into the bonnet.
WANTED:
Edited by user Friday, 11 September 2009 8:48:32 AM(UTC)  | Reason: Not specified
Guest (5)
This page was generated in 0.082 seconds.
