hey dudes a mates putting or going to put straight cut's in his red 308 and he want's to know if there's any mods to be made and if so what are they,is it hard to do. don't know myself never had them always stuck with the chain thanx in advance
On The Other Hand There's Finger's |
No Mods that I know of ,I put one in my car (403 olds with a chev 400 geardrive),easy as (well that wasnt but anyway)...I just lined it up with paper between the gears ,tighten it all up ,then remove the paper.
Jim in adelaide |
Jim in Adelaide.. |
He is aware of the noise they make and the fact that theyre not necessary on street motors?
Other than that, as was mentioned, lash is very important for good operation and life. |
"Silly modern cars" |
i know people who have fitted straight cut gears simpy for the noise alone, apperently "its cool" and makes your car sound tuff
mine arent straight cut they are angled,they sound better i think ,only a slight noise.QUOTE:i know people who have fitted straight cut gears simply for the noise alone, apperently "its cool" and makes your car sound tuff..... absolutly true,....same thing with the geardrive belt thingys,just a matter of taste.(i like them)
Jim in adelaide |
Jim in Adelaide.. |
Thanks: 8 times Was thanked: 16 time(s) in 14 post(s)
Besides the floating idler gear causing stupid amounts of front bearing/cam wear, and the noise, and the fact that a chain does a far better job of damping harmonics, gear drives on street cars that are expected to last 100k miles instead of regular tear downs, are great and a worthwhile investment to any engine. helical cut gears are even more fantastic, if you can put up with excessive thrust bearing wear, and cam end float, or maybe an "aerated" timing case if the correct button isnt used with the correct clearance. Go for it man, gear drives are hell cool! 11.38@117 Edited by user Saturday, 12 September 2009 4:04:35 AM(UTC)
| Reason: Not specified
thanx dudes I have passed on the info he is greatful for the posts he still wants to go ahead (noise) thanx again
On The Other Hand Theres Fingers |
